Export Gantt HTML5 JScript
Posted: Wed Dec 21, 2016 11:12 am
by 16578476
the export of a gantt to HTML5 seems not working well.
Re: Export Gantt HTML5 JScript
Posted: Fri Dec 23, 2016 10:48 am
I've reproduced the problem so I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1727
Thanks for reporting it.
Posted: Fri Dec 23, 2016 2:34 pm
by 16578476
thanks for your reply.
We look at the java script and we see that axes are inverted.
It seems not difficult to correct it. Do you think you could send us a patch?
It's very important for us, when do you think we can have a patch?
Posted: Tue Dec 27, 2016 12:37 pm
by 10050769
Hello Menant,
We aren't sure when you fix the problem. But, when we find a fix for it, we contact immediately with you.
Thanks in advance
Posted: Fri Jul 07, 2017 3:37 pm
by Marc
You can get a copy of the calculated Axis Increment before exporting the Chart.
Eg.
procedure TForm4.Button1Click(Sender: TObject);
  JavascriptExportFormat: TJavascriptExportFormat;
  inherited;
  Chart1.Axes.Bottom.Increment := Chart1.Axes.Bottom.CalcIncrement;
  JavascriptExportFormat            := TJavascriptExportFormat.Create;
  JavascriptExportFormat.Panel      := Chart1;
  JavascriptExportFormat.CanvasName := 'canvas' + intToStr(Tag);
  JavascriptExportFormat.JScript.SaveToFile('GanttTest.html');
The above code tests successfully with the example.
