Horizontal alignment of legend
Posted: Thu Jan 18, 2018 3:41 am
by 9231184
Hi, I was wondering if it was possible to horizontally align the legend (in particular a center alignment). I am aware of vertical alignment however could not find any detail regarding the possibility of horizontal alignment.
Re: Horizontal alignment of legend
Posted: Thu Jan 18, 2018 9:13 am
Have you seen the legend example in the online demos?
You can align the legend to the left, right, top or bottom. Is this what you need?
Posted: Fri Jan 19, 2018 4:19 am
by 9231184
Yeray wrote:Hello,
Hi, I am familiar with this functionality. The problem is once i've set the position to bottom, the legend isn't horizontally aligned to the center as shown in the example below:
https://imgur.com/a/DqTC0
(This image also demonstrates the DateTime issue that occurs occasionally with 4+ series I've posted previously but not of priority as of now).
Posted: Tue Jan 23, 2018 12:06 am
by 9231184
NickH wrote:
Yeray wrote:Hello,
Upon further inspection it appears the issue of horizontal alignment only occurs with the particular charts with multiple series which also has the issue of TDateTime exporting incorrectly. I'll do some further investigation regarding both TDateTime and horizontal alignment of legend and come back
Posted: Tue Jan 23, 2018 10:31 am
I could reproduce the legend "alignment" (it's actually the boundaries) problem so I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1974
The problem with the axis labels looks similar to this one. Could you please confirm it?
