Adding data from a database query
Bruce
Post by Bruce » Wed Dec 02, 2020 9:47 am
What is the recommended was of adding the results of a database query to a Tee.PointXY?
Bruce
Bruce
Re: Adding data from a database query
Post by Yeray » Fri Dec 04, 2020 12:38 pm
You may want to take a look at the Database tutorial here:
https://steema.com/docs/TeeChartVCLDatabase.htm
Bruce
Post by Bruce » Fri Dec 04, 2020 3:15 pm
This is VCL. I'm talking about Javascript.
Bruce
Post by Yeray » Mon Dec 07, 2020 12:30 pm
Ouch, excuse me.
Check the "Data Sources" section in the demos.
If you still find problem with it, please specify what format does the data have after running the query.
Bruce
Post by Bruce » Tue Dec 08, 2020 8:59 am
The demos do not include a database example.
I am currently using PHP to get the data, converting it to a Json array and on a row by row basis adding it to the chart. Is this the only way of doing it?
Bruce
Post by Yeray » Wed Dec 09, 2020 12:43 pm
An alternative would be to convert the data to a JSON structure that can be loaded as in the From JSON example.
