Grid view changes after sorting
stoffman
Post by stoffman » Fri Apr 07, 2023 2:24 am
To recreate:
1. The user scrolls vertically (to the right) and put into view a column that was not first visible
2. Then sorts by this column
The grid scrolls back back to the left (the sort is being maintained)
I'm using: windows 10, Lazarus 2.2.4, Grid 1.1
stoffman
Re: Grid view changes after sorting
Post by stoffman » Fri Apr 07, 2023 2:25 am
Missing is the first state of the grid:
Post by Marc » Fri Apr 21, 2023 12:33 pm
Thank you for the issue report. We will look for a solution for it.
In the meantime there may be some form of workaround available using the current x and y scroll locations taken before the sort.
ie.
  private
    { Private declarations }
    oldX : Single;
    oldY : Single;
You can obtain scroll positions:
type
  MyScrollableControl=class(TScrollableControl);
procedure TMyForm.Button5Click(Sender: TObject);
  oldX := MyScrollableControl(TeeGrid1).GetScrollX;
  oldY := MyScrollableControl(TeeGrid1).GetScrollY;
Those can be restored via:
  MyScrollableControl(TeeGrid1).SetScrollX(oldX);
  MyScrollableControl(TeeGrid1).SetScrollY(oldY);
If you are running the sort from a button then you could add the code in there; if not then we'll likely need to think of another way in.
