Access current row/columns cells
oflor
Post by oflor » Fri Feb 10, 2017 8:42 am
I want to implement a order by column feature.
I want to use the OnClickHeader event to do so, but I don't find a method to know these values or the column number of the header I was clicked to.
David Berneda
Re: Access current row/columns cells
Post by David Berneda » Tue Feb 14, 2017 8:57 am
The "Sender" parameter in the OnClickedHeader event is the column that is under the mouse xy position, you can use it to determine the column index, name etc.
For example:
procedure TFormGridCharts.TeeGrid1ClickedHeader(Sender: TObject);
  Caption:=Sender.ClassName;
  if Sender is TColumn then
     Caption:=Caption+' '+TColumn(Sender).Header.Text+' '+IntToStr(TColumn(Sender).Index);
BUT, I've just found a bug in the code, the OnClickedHeader event is never called.
I'll post asap a "nightly build" with a fix for this issue.
btw: Custom "order by column" (clicking header) will be also included in the "nightly build".
The following demo project shows how to use custom sorting:
https://github.com/Steema/TeeGrid/tree/ ... %20Sorting
David Berneda
Post by David Berneda » Tue Feb 14, 2017 9:53 am
New beta v1.01 release, and a new example showing how to use "custom sorting"
Nightly build:
http://www.steebi.com/files/code/beta/vcl_fmx/teegrid/
regards !
david
