MouseWheel Scrolling
brent
Post by brent » Fri Jun 02, 2017 4:30 pm
I've got the TeeGrid connected to a DataSource. The MouseWheel will not work to scroll. I've tried setting the TeeGrid.Scrolling.Mode to different things.
Also, using the arrow keys will move the indicator position but scrolling doesn't happen.
Brent
Re: MouseWheel Scrolling
Post by Yeray » Thu Jun 08, 2017 1:39 pm
Hi Brent,
This was fixed with #1850 and #1851.
The next maintenance release will include the fix.
The fix is quite simple, if you want to implement in your sources. It consists on adding an override of the DataSetScrolled method at Tee.GridData.DB.pas:
  TVirtualDataLink=class(TDataLink)
  protected
    Procedure DataSetScrolled (Distance :Integer); Override;
Procedure TVirtualDataLink.DataSetScrolled (Distance :Integer);
Begin
  RecordChanged(Nil);
End;
