Filtering in Virtual mode
Jonsafi
Post by Jonsafi » Tue Dec 01, 2020 3:01 pm
am using the nice TVirtualModeData
and successfully use
 procedure GetCell(Sender:TObject; const AColumn:TColumn; const ARow:Integer; var AValue:String);
to populate the data. Would like to add a filter to a certain column,
so that the whole row gets hidden.
So obviously, the following doesn't work since the row gets included with blank values..
if AColumn.Index = column_i Then
Avalue := '';
Is there any way to easily cut off a whole row from the data (prevent it from
being displayed), which has been created normally like so:
 // Create data, with 10 columns, lots of rows, (optionally: a default column width = 60)
Data:=TVirtualModeData.Create(10,20000,60);
Much obliged for your kind help,
Sami
Re: Filtering in Virtual mode
Post by Yeray » Mon Dec 07, 2020 2:44 pm
You should be better removing the data instead of trying to hide a row.
The easiest way to hide a row I found would be to set a very small height to it. Ie:
  TeeGrid1.Rows.Heights[4]:=1/Power10(10,10);
Jonsafi
Post by Jonsafi » Thu Dec 10, 2020 10:44 am
OK, thanks a lot, :D hiding seems like a nice and quick solution.
May be in a future release filtering support will be available.
Take care,
Sami
Post by Yeray » Fri Dec 11, 2020 6:16 pm
Another alternative would be to filter the datasource connected to the grid.
