TeeGrid 1.1, Lazarus 2.2.0 and Linux Installation
Post by » Thu Mar 24, 2022 10:41 pm
Installation of TeeGrid 1.11 Fails on Ubuntu Linux with Lazarus 2.2.0.
System: Linux dev-1 5.13.0-30-generic #33~20.04.1-Ubuntu SMP Mon Feb 7 14:25:10 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Lazarus version: 2.2.0 Feb 01 2022
FPC version: 3.2.2
Installed on to windows machine to get source (really need an archive dist for linux). Moved source to linux box into directory with no spaces in name and tried to install using "Package | Open Package File *.lpk " and selected Sources/Packages/teegrid.lpk
From Package Dialog select Use|Install , compile IDE. and gets error:
Compile package teegrid 9.0: Exit code 1, Errors: 1
VCLTee.Editor.Scrolling.pas(13,13) Fatal: Cannot find windows used by VCLTee.Editor.Scrolling.
Not sure what's up with the different version number in the message above.
Ctrl-Click on Windows unit in uses clause opens windows in editor.
Exact same steps with Lazarus 2.2.0/FPC 3.2.2 on Windows 10 works using same steps. Does not work with automatic installer.
Could use some assistance on this as product has to run on linux.
Re: TeeGrid 1.1, Lazarus 2.2.0 and Linux Installation
Post by Marc » Tue Mar 29, 2022 1:01 pm
We've come across a few errors when compiling on Linux and will need to work our way through them. We'll get back to this thread.
Post by » Sat Apr 02, 2022 5:45 pm
Any progress on this issue ?
Post by Marc » Fri Apr 08, 2022 3:06 pm
This may take us some time. The normal route to Linux that we recommend for TeeGrid is via Firemonkey; but we are looking at the code in Lazarus/Linux for options to compile.
Post by Yeray » Wed Apr 20, 2022 10:43 am
I've just sent a patch to the mail account you have registered in this forum so you can check if it works for you.
Please don't hesitate to let us know if anything doesn't work as expected.
Post by » Tue Apr 26, 2022 12:24 am
Patch installs correctly. The popup edit dialog needs work though, most of the pages have no text and I can't create more than 1 column. Thanks for your work on this.
Post by Yeray » Tue Apr 26, 2022 7:01 am
I'm glad to hear that.
Could you please explain what do you mean with some more detail?
