TeeGrid V1.14 throws exception when trying to debug an application
Posted: Fri Jan 26, 2024 10:46 am
by 16576471
I'm completely new to TeeGrid.
I'm trying to build a tiny test app with an empty TeeGrid to see wether or not it was installed correctly. My steps were:
- Create an empty VCL-Application
- Place a TeeGrid on the Form
- Open the TeeGrid Editor (double click) and add two Columns.
- Set only the "Header" property of each column.
- Save the project and click "Start" (F9) within the IDE.
Before any application Window opens, the application throws an exception: "Invalid property value"
- First
- 01.png (19.52 KiB) Viewed 2838 times
After clicking the button "continue" it shows a 2nd one.
- 02.png (20.46 KiB) Viewed 2838 times
What did I do wrong? Any help is appreciated.
Edit: I didn't attach any data source at all. Only adding two named columns in the editor!
Re: TeeGrid V1.14 throws exception when trying to debug an application
Posted: Fri Jan 26, 2024 11:06 am
by Marc
I followed your steps with a new VCL project in RAD Studio 12 and TeeGrid v1.14 and it built/ran ok.
What version of RAD Studio are you using?
With thanks.
Posted: Fri Jan 26, 2024 11:23 am
by 16576471
Hi Marc, thanks for your reply.
We're using Embarcadero® C++Builder 12 Version 29.0.50491.5718
(Professional)
This is my form as text: I do wonder why it has an underscore in the headers section
_Headers = (
Edit: Removing the underscore is even worse. So I suppose it belongs there!
object Form1: TForm1
Left = 0
Top = 0
Caption = 'Form1'
ClientHeight = 441
ClientWidth = 624
Color = clBtnFace
Font.Charset = DEFAULT_CHARSET
Font.Color = clWindowText
Font.Height = -12
Font.Name = 'Segoe UI'
Font.Style = []
OnCreate = FormCreate
TextHeight = 15
object Button1: TButton
Left = 40
Top = 384
Width = 75
Height = 25
Caption = 'Button1'
TabOrder = 0
end
object TeeGrid1: TTeeGrid
Left = 88
Top = 40
Width = 400
Height = 250
Columns = <
item
Header.Text = 'Test Column 1'
end
item
Header.Text = 'Test Column 2'
end>
UseDockManager = False
ParentBackground = False
ParentColor = False
TabOrder = 1
_Headers = (
1
'TColumnHeaderBand'
item
end>)
end
end
Posted: Fri Jan 26, 2024 12:53 pm
by Marc
Hello, the content for my form Grid is pretty much the same, no FormCreate event or Button but the Grid syntax is identical.
Left = 0
Top = 0
Caption = 'Form1'
ClientHeight = 441
ClientWidth = 624
Color = clBtnFace
Font.Height = -12
Font.Style = []
TextHeight = 15
Left = 80
Top = 112
Width = 400
Height = 250
Columns = <
item
Header.Text = 'test column1'
end
item
Header.Text = 'test column2'
end>
ParentColor = False
TabOrder = 0
_Headers = (
1
'TColumnHeaderBand'
item
end>)
end
end
I'm running the project as Delphi Pascal. I'll have a go at a C++ project.
Please check that you don't have other versions of TeeGrid on your search-path/package-list.
Posted: Fri Jan 26, 2024 1:33 pm
by 16576471
This is the first time ever we're using TeeGrid. There are no other versions in the search path. We do have TeeChart Pro installed, though. But I think this isn't the problem. All the paths have been set up by the installer.
Include-Path:
- inc.png (41.59 KiB) Viewed 2830 times
Library-Path:
- lib.png (33.77 KiB) Viewed 2830 times
I've attached the two stack traces.
First exception:
- EX1.png (92.79 KiB) Viewed 2830 times
by 16576471
Second exception:
- EX2.png (75.95 KiB) Viewed 2830 times
Posted: Fri Jan 26, 2024 1:38 pm
by 16576471
I don't know wether or not it helps, but this is the project file:
Re: TeeGrid V1.14 throws exception when trying to debug an application [FIXED]
Posted: Mon Jan 29, 2024 6:57 am
by 16576471
FIXED IT
In the project options "Packages" --> "Runtime Packages" one must uncheck "link with runtime-packages".
Can somebody please confirm this?
- FIX.png (52.76 KiB) Viewed 2619 times
Posted: Tue Jan 30, 2024 1:56 pm
by Marc
I just checked that. It runs ok with or without the 'runtime packages' selected. It may be something in the package list on your setup that is causing the problem.
TeeGrid is in the package list on the test installation here.
Posted: Fri Feb 02, 2024 9:15 am
by 16576471
I've confirmed that the package "VCLTeeGrid" is in the list. When I try to start the application with runtime packages enabled it crashes upon startup like before. But now i've removed the runtime package "VCLTeeGrid" from the list and it works now with runtime packages enabled!!??
