I would like to get some pointers to implement a feature one of our customers needs. They would like to select (using mouse drag and showing a selection box) a number of shapes in a TMapSeries.
I would like to add this feature as a tool.
Specific questions are:
I have looked at the zoom function which behaves like I would like the selection to behave and would like to use that information (the box) to determine all the shapes that completely fit in the box.
My specific questions:
How do I transform mouse coordinates to the viewport coordinates so I can see what shapes lie within the selection box?
How do I overrule the zoom mechanism to become a selection mechanism?
We will be using the latest version of TeeCharts.
Thanks in advance,
Michael.
Selecting multiple shapes in TMapSeries with mouse drag
Re: Selecting multiple shapes in TMapSeries with mouse drag
Hello Michael,
If I understood it correctly you could do it as follows:
I've disabled zoom and scroll features and I draw the rectangle manually with the Mouse events. I also calculate what shapes have a point inside the rectangle and I change their color.
uses Series, TeeMapSeries, TeCanvas, Math;
var MouseDownX, MouseDownY: Integer;
Chart1.View3D:=false;
Chart1.Legend.Visible:=false;
Chart1.AllowPanning:=pmNone;
Chart1.AllowZoom:=false;
Chart1.AddSeries(TMapSeries).FillSampleValues(15);
MouseDownX:=-1;
MouseDownY:=-1;
MouseDownX:=X;
MouseDownY:=Y;
Y: Integer);
var tmpRect: TRect;
tmpMap: TMapSeries;
tmpPoint: TPoint;
tmpInside: Boolean;
i, j: Integer;
if ((MouseDownX > -1) and (MouseDownY > -1)) then
tmpRect:=Rect(Min(MouseDownX, X), Min(MouseDownY, Y), Max(MouseDownX, X), Max(MouseDownY, Y));
tmpMap:=Chart1[0] as TMapSeries;
for i:=0 to tmpMap.Count-1 do
tmpInside:=false;
for j:=0 to tmpMap.Shapes[i].Points.Count-1 do
tmpPoint:=tmpMap.Shapes[i].Points.Polygon.GetPoints[j];
if (PointInRect(tmpRect,tmpPoint)) then
tmpInside:=true;
break;
if (tmpInside) then
tmpMap.Shapes[i].Color:=clYellow
tmpMap.Shapes[i].Color:=clTeeColor;
with Chart1.Canvas do
Brush.Style:=bsClear;
Pen.Color:=clGrayText;
Chart1.Repaint;
Rectangle(tmpRect);
procedure TForm1.Chart1MouseUp(Sender: TObject; Button: TMouseButton;
MouseDownX:=-1;
MouseDownY:=-1;
Hello Yeray,
This is indeed what I was looking for. And it even works pretty well with large amounts of shapes. Thanks this will save me a lot of time and it can easily be fit into our current functions. I'll see if I can make it into a tool that you can add to a chart.
Michael.
Michael.
I have implemented your solution into our application but when some of my customers wanted to have gradients on the shapes and gradients in the background, shadow effects and highlighted borders the redraw got exceedingly slower. Since this is done every time one shape is selected/deselected this can amount to quite a backlog. Sometimes can take more than 2 second with only three shapes visible.
Is it possible to only update one shape without having to redraw all the other shapes in a series?
Hi Michael,
I guess the problem here is due to custom canvas drawing which requires repainting the chart to run smoothly. This draws the selection rectangle. If you don't need to paint it your application may run quicker. I this doesn't suffice please attach a simple example project we can run "as-is" to reproduce the problem here and we will have a look and see if we can find a way to improve performance.
Hello Narcís,
I have attached the version of my program to this post. The problems start to form when I use the GDI plus for better image quality. Would it be possible to get the selection box shown on the chart as it shows on the non-gdi plus version. What I also see that the gdi plus version draws a lot slower, I understand that it does a lot more than the normal drawing but I had not expected it to be this much. I have removed the gdi plus from my application which helps a lot with regards to repainting.
Thanks again for the help,
Michael
Michael
- ChartTest.zip
- Test project chart selection with and without gdiplus
- (5.97 KiB) Downloaded 1828 times
Hi Michael,
I'm afraid there's a bug with GDI+ canvas which I have added (TV52015765) to the defect list to be investigated. In the meantime, I found that setting Canvas.Pen.Mode to pmNotXor works fine:Would it be possible to get the selection box shown on the chart as it shows on the non-gdi plus version.
Chart2.Canvas.Pen.Mode:=pmNotXor;
We are constantly trying to improve TeeChart performance but this is only possible to some extent as in most circumstances GDI+ is known to be slower than GDI.What I also see that the gdi plus version draws a lot slower, I understand that it does a lot more than the normal drawing but I had not expected it to be this much.
