ErrorBar x-value is not positioned correctly
Hens
Post by Hens » Fri Dec 14, 2007 4:16 pm
I have in different applications a problem with errorbars. I want to plot dot's (measurement values) with errorbars (measurement uncertainty).
But every time the errorbar is placed just a little bit left of the dot. When I zoom in the distance stay's the same. I am sure that I give the same x value (measurement date/time) to both dot and errorbar. This is my code:
aXValue := Fields[2].AsFloat;
aSeries.AddXY(aXValue, aValue[aUnit], '', aColor);
aErrorSeries.AddErrorBar(aXValue, aValue[aUnit], aUnc[aUnit]);
I think that this must be a bug in TErrorbar.
Post by Narcís » Mon Dec 17, 2007 9:55 am
Hi Hens,
Would you be so kind to arrange a simple example project we can run "as-is" and let us know the steps we should follow to reproduce the issue here?
You can either post your files at news://www.steema.net/steema.public.attachments newsgroup or at our upload page.
djsox
ErrorBar Series misplaced
Post by djsox » Thu Jan 03, 2008 6:40 pm
I have also noticed this recently while trying to use the errorbar series. Using version 8 D7 and D2006 Pro.
Dan
Post by Yeray » Fri Jan 04, 2008 9:08 am
Hi Dan and Hens,
Please, send us a simple example as Narcís told you because we're not able to reproduce it. For example, the following seems to be fine here:
var i : Integer;
Y : Double;
  Chart1[0].Clear;
  for i := 0 to 2 do
    Y := random * 100;
    Chart1[0].AddXY(i, Y);
    (Chart1[0] as TErrorBarSeries).AddErrorBar(i, Y, Y+20);
