Steve Maughan
Post
by Steve Maughan » Mon Mar 09, 2009 3:15 pm
I'm adding chart image exporting capabilities to my application. One of the features is that the user can select the size of the resulting image. The code is relatively straightforward. However when the source chart is much bigger than the resulting image, the axis labels get "scrunched up". See below:
Here is a demo project to illustrate what I'm doing:
http://www.cozmix.com/misc/tchartscale.zip
What I would like would be for the axis label to re-calibrate on the exported image like they do when you reduce the size of a TChart e.g.
Is this possible? I hope there's a way to do this!
Steve
Post
by Yeray » Tue Mar 10, 2009 12:54 pm
Hi Steve,
I've tested your sample application and I've seen that using Assign method causes some strange behavior with the axes.
I've added this to be revised for further releases (TV52013950), but in the meanwhile, please use the following code instead of Assign method. This seems to work fine:
With xChart do
ColorPaletteIndex := Chart1.ColorPaletteIndex;
Foot := Chart1.Foot;
Legend := Chart1.Legend;
SubFoot := Chart1.SubFoot;
SubTitle := Chart1.SubTitle;
Title := Chart1.Title;
Walls := Chart1.Walls;
Steve Maughan
Post
by Steve Maughan » Tue Mar 10, 2009 1:08 pm
Yeray,
Thanks for looking into it. I have tested the solution and it seems to work - many thanks. However, I don't understand how you can assign object pointers, free the object and not have an AV. For example, will Chart1.Foot etc be freed when xChart is freed?
Cheers,
Steve
Steve Maughan
Post
by Steve Maughan » Tue Mar 10, 2009 2:55 pm
Yeray,
On further investigation I realize that (of course) the Axis formats are not copied. So this is definitely a high priority fix for me. Hotfixes are welcome!
Steve
Post
by Narcís » Tue Mar 10, 2009 3:48 pm
Hi Steve,
No, Chart1.Foot will be freed by Chart1's destructor when it's freed.
Steve Maughan
Post
by Steve Maughan » Thu Mar 19, 2009 3:18 pm
9348257 wrote:I've added this to be revised for further releases (TV52013950)....
Has this bug been fixed? It's getting really quite urgent. Any idea when it will be fixed?
Steve
Post
by Narcís » Fri Mar 20, 2009 11:38 am
Hi Steve,
The issue hasn't been fixed yet nor I can provide an estimate date at the present moment. In the meantime you can use the workaround Yeray suggested.
Steve Maughan
Post
by Steve Maughan » Fri Mar 20, 2009 11:41 am
Thanks for the reply. The work around does not copy all of the properties over e.g. the axis format and min max properties are not copied. So I really would like to see a fix for this problem.
Many thanks,
Steve Maughan
