If I add DateTime Values to the bottom axis an open a Charteditor at runtime, the x values are shown correctly but the y values show the DatTime FormatString ('hh:mm') instead of the correct data. y data points are simple integer values.
See attachment.
Any suggestion about that behavior?
TeeChart 8 pro / RAD 2009
Regards, Messie
Wrong Data shown in TChartEditor using DateTime Values
- ChartEditor.GIF (56.72 KiB) Viewed 8754 times
Re: Wrong Data shown in TChartEditor using DateTime Values
Hi Messie,
Could you please attach a simple example project we can run as-is to reproduce the problem here?
The following code seems to work as expected here:
uses Series, GanttCh;
var Series1: TGanttSeries;
i: Integer;
Series1 := TGanttSeries.Create(self);
Chart1.AddSeries(Series1);
for i := 0 to 9 do
Series1.AddGantt(Now()+i, Now()+i+10, random*100);
Ok, here we are.
Regards, Messie
Regards, Messie
- DateTime Problem Demo.zip
- (6.01 KiB) Downloaded 608 times
Hi Messie,
I see in your project that you've changed you series' ValueFormat from #,##0.### to hh:mm at design time. Note that this is for the YValues, so here it is the explanation of your result.
If you still find problems with anything, don't hesitate to let us know.
Yes, you're right. I thought that this was the correct position to set. So where can I set the format string for the DateTime X Axis?
Thanks, Ulfert
Thanks, Ulfert
Hi Messie,
To show hours:minutes in the bottom axis you should do as follows:
Note that this is explained at the Tutorial 4 - Axis Control. You'll find tutorials and demos at TeeChart programs group.
Series1.XValues.DateTime := true;
Chart1.Axes.Bottom.DateTimeFormat := 'hh:mm';
