stacked bar of uneven width
Steffen
Post by Steffen » Sun Nov 29, 2009 8:21 pm
When displaying crossTab stacked bars, width of the stacked bar is not uniform. The green series (in this case) is wider.
Is this a known problem?
I use 8.06 Pro.
Best regards,
S. Wagner
bar with uneven width.jpg (4.43 KiB) Viewed 9069 times
Re: stacked bar of uneven width
Post by Yeray » Mon Nov 30, 2009 11:14 am
Hi S. Wagner,
I've tried to reproduce it with the demo at All features\Welcome !\Database Charts\DB Crosstab source but couldn't. Could you please send us a simple example project we can run as-is to reproduce the problem here? Thanks in advance.
Steffen
Post by Steffen » Mon Nov 30, 2009 3:05 pm
where would I send it to?
Brgds.
Steffen
Post by Narcís » Mon Nov 30, 2009 3:23 pm
Hi Steffen,
You can attach your files to your forums posts at the "Upload attachment" tab below the message text window.
Steffen
Post by Steffen » Mon Nov 30, 2009 3:26 pm
Hola muchachos,
here comes the sample project (compiled with D6 and Advantage Database client)
Brgds.
Steffen
sample.zip
(498.29 KiB) Downloaded 552 times
Post by Yeray » Wed Dec 02, 2009 11:21 am
Hola Steffen!
Could you please try adding the following?
Series1.BarWidthPercent:=70;
Steffen
Post by Steffen » Wed Dec 02, 2009 2:00 pm
"70" does the trick!
It seems to be Teechart's magic number as it does not work with any other (I tried 65, 75 and 80).
If Editor (Series-Format-Size-Bar width) is set to "70", then additional line
Series2.BarWidthPercent := 70;
is not even necesarry.
To me, this looks like a bug, isn't it?
Thanks anyway,
Steffen
Post by Yeray » Fri Dec 04, 2009 3:43 pm
Hi Steffen,
I've added this to the wish list to be revised in future releases (TV52014584).
