Chartlistbox and Hover Effect?
moelski
Post by moelski » Wed Jan 13, 2010 7:56 am
Hi !
Is it possible to detect if the mouse is over an item/series in the chartlistbox (without clicking the mouse)?
Let´s think about the following situation:
You have 10 or more active curves in your chart. Now the users hovers over the chartlistbox and the series items.
If there is any chance to detect the series where the mouse is over this series could be painted with a line pen width +1 as long as the mouse is over the series.
Greetz
Dominik
Re: Chartlistbox and Hover Effect?
Post by Yeray » Wed Jan 13, 2010 11:22 am
Hi Dominik,
Taking this example as reference, it is easy to obtain the following solution:
uses series;
var selectedSeries: Integer;
var i: Integer;
  chart1.View3D:=false;
  for i := 0 to 5 do
    Chart1.AddSeries(TFastLineSeries.Create(self));
    Chart1[i].FillSampleValues();
  Chart1.Legend.CheckBoxes:=true;
  selectedSeries:=-1;
procedure TForm1.Chart1MouseMove(Sender: TObject; Shift: TShiftState; X,
  Y: Integer);
var i: Integer;
    tmpPnt: TPoint;
    tmpRect: TRect;
  tmpPnt.X:=X;
  tmpPnt.Y:=Y;
    tmpRect.Left:=Chart1.Legend.Left;
    tmpRect.Right:=Chart1.Legend.Left + Chart1.Legend.Width - 1;
    tmpRect.Bottom:=Chart1.Legend.Item[i].Top + Chart1.Legend.Item[i].SymbolRect.Bottom - Chart1.Legend.Item[i].SymbolRect.Top + 3;
    if (i = 0) then tmpRect.Top:=Chart1.Legend.Item[i].Top-3
    else tmpRect.Top:=Chart1.Legend.Item[i].Top-2;
    if PtInRect(tmpRect,tmpPnt) then
      if selectedSeries>-1 then Chart1[selectedSeries].Pen.Width:=1;
      selectedSeries:=i;
      Chart1[selectedSeries].Pen.Width:=3;
      break;
moelski
Post by moelski » Thu Jan 14, 2010 8:38 am
that´s not what I need.
I want to hover over the ChartListBox - not over the Chart.
In easy words I need this:
Hover over a series in the ChartListBox and repaint the corresponding series with a line width +1 (as long as the hover takes).
Post by Yeray » Thu Jan 14, 2010 3:07 pm
Hi Dominik,
Excuse me, I missed that. But the solution for a ChartListBox isn't very different:
uses series;
var i: Integer;
  ChartListBox1.Chart:=Chart1;
  for i := 0 to 5 do
  Chart1.Legend.Visible:=false;
  selectedSeries:=-1;
procedure TForm1.ChartListBox1MouseMove(Sender: TObject; Shift: TShiftState; X,
  Y: Integer);
var i: Integer;
    tmpPnt: TPoint;
    tmpRect: TRect;
  tmpPnt.X:=X;
  tmpPnt.Y:=Y;
    if PtInRect(ChartListBox1.ItemRect(i),tmpPnt) then
      selectedSeries:=i;
      Chart1[selectedSeries].Pen.Width:=2;
      break;
