Using World Maps
TCardinal
Using World Maps
Post by TCardinal » Fri Mar 12, 2010 4:37 pm
Is there an example of creating points on a map using longtitude and latitude?
thanks
Re: Using World Maps
Post by Narcís » Fri Mar 12, 2010 4:46 pm
Hi TCardinal,
Yes, the TeeMaps example included with TeeChart's installation, for example at: C:\Program Files\Steema Software\TeeChart 8.06 for Delphi 2007\Examples\TeeMaps; includes a city list which are plotted using longitude and latitude coordinates.
Hope this helps!
TCardinal
Post by TCardinal » Fri Mar 12, 2010 5:26 pm
Thanks, that would be what I am after. Unfortunately the example app won't load as it requires DotNet Personality. Even trying to compile the unit in a new app, won't compile as it needs TeeObjectInspector which I can't find in my installation.
Post by Yeray » Mon Mar 15, 2010 10:24 am
Hi TCardinal,
To fix the DotNet Personality problem, try deleting the .dproj file and loading the .dpr project.
To fix the TeeObjectInspector dependence, add the folder "Examples\TeeChartOffice\Sources" to your TeeMaps project's search path or copy "TeeObjectInspector.dcu" and "TeeObjectInspector.pas" from that folder to your TeeMaps demo folder "Examples\TeeMaps".
It should be fine with the next maintenance release.
