TPieSeries problem with OtherSlice
mSchenkel
Post by mSchenkel » Thu Mar 25, 2010 3:50 am
I am finding if my series has a lot (i.e. ~100) of data points and I use the "OtherSlice" property to reduce the number of slices it shrinks the entire chart. Everything else is working (i.e. data points not making the otherslice value are placed in the "other" slice).
Here is an example where I use "OtherSlice" against ~100 data points:
Shrinks File
Here is an example where I aggregate myself, reducing down to 10 points:
Good Rendering
Re: TPieSeries problem with OtherSlice
Post by Yeray » Fri Mar 26, 2010 3:20 pm
Hi mSchenkel,
Could you please send us a simple example project we can run as-is to reproduce the problem here?
The following code tries to draw a chart similar to yours and it seems to be drawn as expected:
uses series;
var pie: TPieSeries;
    i: Integer;
  pie:=Chart1.AddSeries(TPieSeries.Create(self)) as TPieSeries;
  pie.Add(413,'(not set)');
  pie.Add(266,'California');
  pie.Add(327,'England');
  pie.Add(805,'New York');
  for i:=0 to 25 do
    pie.Add(150,IntToStr(i));
  pie.OtherSlice.Value:=200;
  pie.OtherSlice.Style:=poBelowValue;
