PieChart 3D alignment
Re: PieChart 3D alignment
Post by Yeray » Wed Oct 06, 2010 2:46 pm
Hi X-ray,
I'm afraid you are right. TV52014983 and TV52015159 haven't been fixed yet.
For TV52015159 there was a workaround proposed some posts above, but for TV52014983 I'm afraid I can't think on any.
X-ray
Post by X-ray » Thu Oct 07, 2010 6:42 am
I have to say I am a bit disappointed by this kind of "Support". When I report these kind of bugs for example to Developer Express,
then most of the time I have an useful answer within one or two days. And if it is an urgent problem I can immediately download the fixed sources.
Here waiting for some months there is one maintenance release, the bugs are not fixed and there is no mentioning of a workaround.
This makes the current version totally useless for our product.
A not so happy customer,
X-ray
Post by Marc » Thu Oct 07, 2010 12:04 pm
Hello X-Ray,
Our apologies that these related issues have not been resolved in time for this latest maintenance release. We'll review them immediately and see if we can get a resolution to you very shortly.
X-ray
Post by X-ray » Thu Oct 07, 2010 1:19 pm
Hi Marc,
Thank you very much for your kind answer; that gives me some hope!
And please don’t misunderstand me, TChart is a great product, I am using it since years and I don’t know of any other charting tool that comes close when it is about plotting quality and amount of features.
Unfortunately we are close to a release and I have to deliver a software product that simply works, but the mentioned bugs, especially TV52014983, are killing. With TV52015159 I can live, although fixing it in my code means changes all over the place. After each switch from OpenGL to GDI and back I have to apply extra code.
best regards,
X-Ray
Post by Narcís » Fri Oct 08, 2010 9:31 am
Hi X-Ray,
Which is the exact TeeChart version you are using? Have you tried with v2010.01.11004 published last Tuesday? We have checked that TV52015159 works fine without using the workaround with this version. Can you please confirm that? As far as TV52014983 concerns, we are currently working on a solution. We will get back to you with fixed sources ASAP.
X-ray
Post by X-ray » Fri Oct 08, 2010 12:34 pm
Hi Narcis,
I didn't download and test version v2010.01.11004, because both bugs (TV52015159 and TV52014983) were
not mentioned in the current Release Notes. I will immediately download/integrate this version and test it today or more probably monday.
best regards,
Thomas
Post by Narcís » Fri Oct 08, 2010 12:56 pm
Hi Thomas,
Ok, thanks for your feedback. TV52015159 is not in the release notes because probably it was indirectly fixed for other improvements in OpenGL for TeeChart.
X-ray
Post by X-ray » Fri Oct 08, 2010 1:48 pm
Hi Narcis,
yes, I can definitely confirm that bug TV52015159 is solved in release v2010.01.11004!
That helps already a lot!
Thanks and best regards,
X-Ray
X-ray
Post by X-ray » Wed Oct 13, 2010 1:26 pm
Hi Narcis,
do you have any news concerning TV52014983?
I would be glad to betatest even an experimental first fix.
best regards,
X-Ray
Post by Narcís » Wed Oct 13, 2010 1:38 pm
Hi X-Ray,
Yes, I think we have a first fix proposal. It may not be 100% complete but I'll send you current OpenGL canvas unit. Please let us know how it goes at your end.
X-ray
Post by X-ray » Wed Oct 13, 2010 2:24 pm
Hi Narcis,
when I try to compile this I get the following error message (both by TeeRecompile tool as well
as in the Delphi UI):
TeeGL911
Cannot recompile Delphi package: TeeGL911.dpk
CodeGear Delphi for Win32 compiler version 18.5
Copyright (c) 1983,2007 CodeGear
TeeGLCanvas.pas(2959) Error: E2250 There is no overloaded version of 'Point3D' that can be called with these arguments
TeeGL911.dpk(39) Fatal: F2063 Could not compile used unit 'TeeGLCanvas.pas'
EXCEPTION:
Compilation aborted.
best regards,
X-Ray
Post by Narcís » Wed Oct 13, 2010 2:44 pm
Hi X-Ray,
Ok, you need updated TeCanvas.pas too then. I just emailed it to you.
X-ray
Post by X-ray » Wed Oct 13, 2010 2:52 pm
Hi Narcis,
now I get:
TeeChart Pro
Compilation started: 10/13/2010 4:47:47 PM
RAD 2007.Win32 v11 (BDS v5 Enterprise)
Tee911
Cannot recompile Delphi package: Tee911.dpk
TeEngine.pas(9851) Error: E2015 Operator not applicable to this operand type
Tee911.dpk(54) Fatal: F2063 Could not compile used unit 'TeEngine.pas'
EXCEPTION:
best regards,
X-Ray
Post by Narcís » Wed Oct 13, 2010 3:03 pm
You'll need TeEngine.pas as well. Just sent it.
Please let me know if any other error occurs.
X-ray
Post by X-ray » Wed Oct 13, 2010 3:14 pm
Hi Narcis,
now I get this:
TeeChart Pro
Compilation started: 10/13/2010 5:07:59 PM
Tee911
82214 lines, 0.61 seconds, 567252 bytes code, 9436 bytes data.
TeeUI911
Cannot recompile Delphi package: TeeUI911.dpk
TeeEdi3D.pas(294) Error: E2010 Incompatible types: 'Boolean' and 'TCanvasZoomText'
TeeEdi3D.pas(327) Error: E2010 Incompatible types: 'TCanvasZoomText' and 'Boolean'
TeeEditCha.pas(360) Fatal: F2063 Could not compile used unit 'TeeEdi3D.pas'
EXCEPTION:
best regards,
X-Ray
