After upgrading from TeeChart 7 to TeeChart 2010 I tried to use tool TAntiAliasTool. Unfortunately TChart doesn't clip line series if TAntiAliasTool is active. Is it a bug or some TChart properties should be set to enable clipping?
Jarek
- TestChartAA.zip
- Test project
- (89.92 KiB) Downloaded 512 times
- Screenshot
- Screenshot.png (66.26 KiB) Viewed 8512 times
Re: TChart doesn't clip line series if TAntiAliasTool is active
Hi Jarek,
This is a known problem already in the defect list to be fixed in future releases (TV52015427).
However, with GDI+ clips the points correctly in the chart rect.
uses Series, TeeAntiAlias, TeeGDIPlus;
Chart1.View3D:=false;
Chart1.Legend.Visible:=false;
//Chart1.Tools.Add(TAntiAliasTool);
Chart1.Canvas:=TGDIPlusCanvas.Create;
Chart1.AddSeries(TFastLineSeries).FillSampleValues;
Chart1.ClipPoints:=true;
Thank you for your help. Now it works.
Where can I find defect list to be fixed in future releases?
Jarek
Jarek
Hi Jarek,
The list is not public but you can subscribe to: this forum, our RSS news feed, Steema Software's twitter or facebook acounts for new release announcements and what's implemented on them.
I've installed TeeChart 2011.03 and tested bugfix:
16) [TV52015427]
TAntiAliasTool not clipping series points correclty. Fixed.
As you can see in an attached screenshot, almost all lines connecting points aren't drawn at all. Line connecting two clipped points is not clipped.
Jarek
16) [TV52015427]
Jarek
- TeeChartAA-2011.03.png (50.73 KiB) Viewed 8448 times
With the latest release, TeeChart v2011.03.30407, I also get this error on line series when the pen width is 2 pixels.
If I change to 1 or 3 pixels for the lines pen, it renders ok.
It worked in the release 2010.02.20202.
Hello Jarek,
You are right. I inform you we are working with this bug to fix the problem as soon as possible.
