TeeChart2011 PreReleaseXE TeeRecompile error
vlezhu
Post by vlezhu » Wed Oct 05, 2011 7:32 am
I can't start TeeRecompile, the error is:
Can't start as FastMM_FullDebugMode.dll is absent
Re: TeeChart2011 PreReleaseXE TeeRecompile error
Post by Narcís » Wed Oct 05, 2011 7:38 am
Hi vlezhu,
Thanks for reporting. We will investigate the issue. In the meantime you can download FastMM files at http://sourceforge.net/projects/fastmm/
vlezhu
Post by vlezhu » Wed Oct 05, 2011 8:05 am
But after FastMM install:
Cannot recompile C++ Builder package: TeeMaker1C6.mak
MAKE Version 5.2 Copyright (c) 1987, 2000 Borland
D:\Cbuild6\bin\..\BIN\bcc32 -O2 -H=D:\Cbuild6\bin\..\lib\vcl60.csm -Hc -Vx -Ve -X- -a8 -6 -b- -k- -vi -c -tWM -w-par -I;D:\Cbuild6\bin\..\include;D:\Cbuild6\bin\..\include\vcl -D;NO_STRICT;_RTLDLL;USEPACKAGES -n.\ .\TeeMaker1C6.CPP
Borland C++ 5.6.4 for Win32 Copyright (c) 1993, 2002 Borland
.\TeeMaker1C6.cpp:
Loaded pre-compiled headers.
D:\Cbuild6\bin\..\BIN\dcc32 -$Y- -$L- -$D- -$A8 -Q -v -JPHNE -M -U;PNGImage;..\..\Sources9 -U;D:\Cbuild6\bin\..\include;D:\Cbuild6\bin\..\include\vcl -D;NO_STRICT;_RTLDLL;USEPACKAGES -O;D:\Cbuild6\bin\..\include;D:\Cbuild6\bin\..\include\vcl --BCB .\TeeBlocks.PAS
Borland Delphi Version 14.0
Copyright (c) 1983,2002 Borland Software Corporation
13561 lines, 0.25 seconds, 106475 bytes code, 54 bytes data.
D:\Cbuild6\bin\..\BIN\dcc32 -$Y- -$L- -$D- -$A8 -Q -v -JPHNE -M -U;PNGImage;..\..\Sources9 -U;D:\Cbuild6\bin\..\include;D:\Cbuild6\bin\..\include\vcl -D;NO_STRICT;_RTLDLL;USEPACKAGES -O;D:\Cbuild6\bin\..\include;D:\Cbuild6\bin\..\include\vcl --BCB .\TeeMakerEditor.PAS .\TeeChart3D.PAS
6648 lines, 1.03 seconds, 1523 bytes code, 4 bytes data.
D:\Cbuild6\bin\..\BIN\ilink32 @MAKE0000.@@@
Turbo Incremental Link 5.64 Copyright (c) 1997-2002 Borland
Fatal: Unable to open file 'BASS.LIB'
** error 2 ** deleting TeeMaker1C6.bpl
Post by Narcís » Wed Oct 05, 2011 8:23 am
Hi vlezhu,
What about disabling Tee 3D packages on the top-right and compile again?
vlezhu
Post by vlezhu » Wed Oct 05, 2011 9:04 am
After disabling Tee3D:
Cannot recompile C++ Builder package: TeeTree2C6Tee9.mak
D:\Cbuild6\bin\..\BIN\bcc32 -Od -H=D:\Cbuild6\bin\..\lib\vcl60.csm -Hc -Vx -Ve -X- -r- -a8 -b- -k -y -v -vi- -c -tWM -w-par -Ic:\Program Files\Steema Software\TeeChart Pro 2011 Full Source Code\Sources\Compiled\Builder6\Include;c:\Program Files\Steema Software\TeeChart Pro 2011 Full Source Code\Sources\..\TeeTree\Sources9\Compiled\Builder6\Include;D:\Cbuild6\bin\..\include;D:\Cbuild6\bin\..\include\vcl -D_DEBUG;_RTLDLL;NO_STRICT;USEPACKAGES -n.\ .\TeeTree2C6Tee9.cpp
Error E2194: Could not find file 'Files\Steema.cpp'
Error E2194: Could not find file 'Software\TeeChart.cpp'
Error E2194: Could not find file 'Pro.cpp'
Error E2194: Could not find file '2011.cpp'
Error E2194: Could not find file 'Full.cpp'
Error E2194: Could not find file 'Source.cpp'
Error E2194: Could not find file 'Code\Sources\Compiled\Builder6\Include;c:\Program.cpp'
Error E2194: Could not find file 'Code\Sources\..\TeeTree\Sources9\Compiled\Builder6\Include;D:\Cbuild6\bin\..\include;D:\Cbuild6\bin\..\include\vcl.cpp'
.\TeeTree2C6Tee9.cpp:
EXCEPTION:
Compilation aborted.
Post by Narcís » Wed Oct 05, 2011 9:07 am
Hi vlezhu,
And disabling TeeTree packages as well?
vlezhu
Post by vlezhu » Wed Oct 05, 2011 9:11 am
But disabling TeeTree packages will help, as TeePro file now were gotten, this error was in the April realease, as I remember and I had to use binary installer
Post by Narcís » Wed Oct 05, 2011 12:07 pm
Hi vlezhu,
Yes, I checked that and I added the issue (TV52015776) to the bug-list to be fixed as soon as possible.
Regarding the FastMM files issue, you shouldn't need them, they should only be used in-house. We will try to fix this as well.
Post by Narcís » Thu Oct 06, 2011 5:54 am
Hi vlezhu,
Find attached updated TeeRecompile version. Can you please check if this solves the FastMM issues at your end?
TeeRecompile.zip
(392.75 KiB) Downloaded 1307 times
vlezhu
Post by vlezhu » Thu Oct 06, 2011 6:04 am
Hi Narcís
No, this TeeRecompile gave me the same error, can't start without FastMM
Post by Narcís » Thu Oct 06, 2011 8:00 am
Hi vlezhu,
Can you please try this version? I checked it works fine for me here.
TeeRecompile.zip
(462.37 KiB) Downloaded 1370 times
vlezhu
Post by vlezhu » Thu Oct 06, 2011 10:22 am
I tested the latest, but have the same error, I am working on Win7-32 Russion locale, may be this is the reason? If I'put fastMM dll to the same directory I can start TeeRecompile
Post by Narcís » Tue Oct 11, 2011 11:25 am
Hi vlezhu,
Can you please try with this new TeeRecompile version?
TeeRecompile.zip
(462.95 KiB) Downloaded 1318 times
Tee8Beta
Post by Tee8Beta » Tue Oct 11, 2011 4:19 pm
No, does not work again, I've just tested on my home PC with Win7-32 and got the same error.
If I'll copy FastMM.dll, teerecompile will start fine.
The previous version I've tested in my office's PC
Both computers have Win7-32 and RadStudioXE and CBuilder6.
Vladimir (vlezhu).
Post by Yeray » Thu Oct 13, 2011 3:08 pm
Hello Vladimir,
We haven't forgotten you. We will probably publish a new PreRelease version as soon as we'll solve some problems we've identified.
