HTML5 export missing settings
I have a chart that I export to HTML5.
TeeSaveToJavascriptFile(Chart1, 'rr.html', 0, 0);
It has 2 series where the first is hidden.
The series is not gradient
The legend is does not have shadow
The legend is transparent
Here is the settings that are missing then I export the chart:
Series1.visible=false;
Series1.format.gradient = false;
Chart1.legend.format.shadow.visible = false;
This I did not find:
Chart1.legend.format.transparent = false;
It may be other settings missing to?
I use XE2 with latest version of Teechart
Jørgen
Jørgen
Re: HTML5 export missing settings
Hi Jørgen,
Note the Javascript version is quite new and thus the exportations from the different versions to it.
So yes, there are probably more properties that are still not considered in it.
Please, don't hesitate to let us know anyone you may suspect it's missing and we'll try to implement them in future releases.
would you add the missing settings in my post in the next release?
Jørgen
Jørgen
Hi Jørgen,
They should be already. I'll send you a testing SourceCode installer to the mail account you have registered in this forum.
I downloaded the file, but it did not change the export
Here are more settings missing:
Chart1.zoom.enabled=false;
Chart1.scroll.enabled=false;
Series2.format.gradient = false;
Chart1.title.format.font.shadow.visible=false;
Series2.format.shadow.visible=false;
Chart1.walls.back.visible=false;
Chart1.panel.transparent=true;
This I did not find
Chart1.legend.symbol.shadow.visible = false;
and
Jørgen
This I did not find
and
Jørgen
- rrr.zip
- (1.01 KiB) Downloaded 971 times
Hi Jørgen,
I'll send you the actual TeeJavascript.pas and TeeChart-min.js so you can test the latest changes.
We'll be very glad to hear about your tests.
Now it is much better!
Added attachment with some issues/missing settings.
Jørgen
Jørgen
- Tee2.zip
- (295.55 KiB) Downloaded 1010 times
Here is one more question.
Can the series be transparent?
Jørgen
Jørgen
- transparent.zip
- (136.39 KiB) Downloaded 895 times
More issues:
borders,stacked series, axis value
Jørgen
Jørgen
- Chart_HTML5.zip
- (506.48 KiB) Downloaded 1017 times
Hi Jørgen,
Thank you very much for the tests!
Just note a tee file or a simple delphi project would let us check all the properties more easily.
Here are 3 teefiles with html5 exports
- Chart.zip
- (18.48 KiB) Downloaded 984 times
Any progress on this?
Jørgen
Jørgen
Hi Jørgen,
Excuse us for the delay here.
We've implemented a few more enhancements like the null values.
I'll send the actual js to the mail account you have registered to this forum for testing purposes.
Maybe a little better
If you export a chart from vcl null values are still exported as 0 so the changes in teechart.js doesn't help.
First focused series is still black
I need an estimated time for a then you have a working version of the export.
The current version can not be used.
Jørgen
Jørgen
