Limit TMarksTipTool popup
INL2
Post by INL2 » Thu Jun 06, 2013 6:58 pm
I currently have a TMarksTipTool and it pops up every time the mouse is anywhere on the chart (See popup 1).
However, it only updates (calls OnGetText) if the mouse is over actual data in the graph. (See popup 3).
Is there a way to make it so that the popup doesn't happen unless it is over a data item.
Or why does it not call OnGetText before it shows every time, instead of just when it is over new data?
Updated when mouse is over the data
Tip not updated unless mouse move over item
Tips shown when not on graph data
Re: Limit TMarksTipTool popup
Post by Yeray » Fri Jun 07, 2013 8:47 am
Is that a TBarSeries? I've tried to reproduce the problem here but the code below seems to work fine for me:
uses Series, TeeTools;
  Chart1.View3D:=false;
  Chart1.AddSeries(TBarSeries).FillSampleValues;
 Chart1.Tools.Add(TMarksTipTool);
I see the popup only when I stop moving the mouse over a bar, and not over an empty space in the chart.
I've also tried assigning a dummy OnGetText event:
  with Chart1.Tools.Add(TMarksTipTool) as TMarksTipTool do
    OnGetText:=MarkTipsGetText;
procedure TForm1.MarkTipsGetText(Sender:TMarksTipTool; var Text:String);
  Text:='hello';
But I get a similar result. The popup is only shown when I'm over the series.
INL2
Post by INL2 » Fri Jun 07, 2013 3:00 pm
There are several things in the cart. The one producing the bars is an Area.
Post by Yeray » Mon Jun 10, 2013 8:36 am
I tried now with this code and the MarkTips tool still doesn't appear when I'm above a part of the chart without any series drawn:
uses Series;
  Chart1.AddSeries(TLineSeries).FillSampleValues;
  Chart1.AddSeries(THorizLineSeries).FillSampleValues;
  Chart1.AddSeries(TAreaSeries).FillSampleValues;
  Chart1.AddSeries(TPointSeries).FillSampleValues;
  Text:='hello';
Pleas, arrange a simple example project we can run as-is to reproduce the problem here.
INL2
Post by INL2 » Tue Jun 11, 2013 3:33 pm
Here is a simple Form that has the problem.
It doesn't start showing the popup text right away, you have to scroll over a bar for a while first and then move back over the empty space.
It calls the GetText every time you go over a bar, but just displays the last one when you are over the empty area.
INL2
Post by INL2 » Tue Jun 11, 2013 3:36 pm
Didn't accept the dcu and dfm, so I put it in a zip.
TChartTest.zip
formMain
(5.43 KiB) Downloaded 999 times
Post by Narcís » Thu Jun 13, 2013 11:07 am
Hi INL2,
.dcu files are not necessary, they are generated with the compilation process. However, the .pas files are necessary. Could you please also send form's .pas and, if possible, project's .dpr?
INL2
Post by INL2 » Mon Jun 17, 2013 1:53 pm
Sorry, I meant to send the .pas, lets try this again.
MainFiles.zip
(3.44 KiB) Downloaded 918 times
Post by Yeray » Wed Jun 19, 2013 11:09 am
The project uses TestForm unit that isn't included in the zip. Since I saw FormMain2 is included but not used, I changed one for the other.
MainFiles.zip
(4.21 KiB) Downloaded 1088 times
If I deactivate the series that don't have a MarkTips tool assigned, it seems to work fine. Could you please confirm this?
INL2
Post by INL2 » Tue Jun 25, 2013 1:03 pm
Still has issues for me.
(See pictures)
The # in the popup is the same.
It pops up when not on the bars.
I remembered we are a version behind because we had some conflicts with your latest version. Is this an issue that has already been fixed.
Post by Narcís » Thu Jun 27, 2013 11:09 am
The issue is much simpler. It's just a problem of having 2 area series in a chart with an associated MarkTips tool each. You can reproduce it with the attached project. I think this is a bug and added it (TV52016624) to the defect list to be fixed for future releases. The solution is pretty simple though, you should just have a single MarkTips tool for all series, not associated to any particular series.
MultiMarkTips.zip
(2.75 KiB) Downloaded 946 times
INL2
Post by INL2 » Wed Aug 28, 2013 9:17 pm
Sorry for the long delay, but project got postponed.
If I make one MarkTips for all the series, how do I know what series I am dealing with inside the function MarkTips___GetText(Sender : TMarksTipTool; var Text : string)
Since sender.Series is nil when you have the "Mark Tips" "Series" assigned to "(all)"
Post by Yeray » Fri Aug 30, 2013 11:04 am
You could know it doing something like this:
procedure TForm1.ChartTool1GetText(Sender: TMarksTipTool;
  var Text: String);
var i: Integer;
    MousePos: TPoint;
  MousePos:=Chart1.GetCursorPos;
  for i:=Chart1.SeriesCount-1 downto 0 do
    if Chart1[i].Clicked(MousePos)>-1 then
      Caption:='SeriesIndex: ' + IntToStr(i);
      exit;
