Export format problem
zyma
Post by zyma » Tue Nov 26, 2013 7:09 pm
We are using the lastest version of Tchart and if we call the Export dialog, there is an error when selecting HTML Table or Excel or JSON format on the Data tab.
If we select HTML Table and click Save... the data are saved in JSON format.
If we select Excel and click Save. the data are saved in HTML format.
If we select JSON and the data are saved in XLS format
See the enclosed project
BugExportTChart.zip
(57.49 KiB) Downloaded 577 times
Re: Export format problem
Post by Narcís » Wed Nov 27, 2013 10:36 am
This is a bug which I have added to bugzilla ([ID483]) to be fixed in future releases. If you sign up to bugzilla you'll be able to follow up the issues you reported and get notifications about their evolution.
Post by Narcís » Thu Nov 28, 2013 2:26 pm
This bug has been fixed now. I'm going to send you an email with the fixed unit so that you can test it at your end.
dsn
Post by dsn » Fri Dec 06, 2013 1:05 pm
Would it be possible to also get the fixed unit? A customer reported this issue a few days ago.
Post by Narcís » Mon Dec 09, 2013 8:02 am
Hi dsn,
Yes, just sent them.
