I have added some MarkText to series marks, and all works well unless the user moves the text boxes and also moves the scroll bar.
If the user moves the MarkText and then scrolls, the MarkText stays in the same screen position, and does not move with the rest of the cart. This happens for all unmoved MarkText items after the one moved, but any unmoved ones before it work fine. Once you scroll to where the item would no longer be visible, then it just disappears.
I was using 8.06 but upgraded to version 8.08 and the problem still exists.
See Attached Pictures.
MarkText SeriesPt not scrolling Correct
- Original Location
- MarkText1.png (8.57 KiB) Viewed 8377 times
- Scrollbar Moved
- MarkText2.png (10.04 KiB) Viewed 8335 times
Re: MarkText SeriesPt not scrolling Correct
Take a look at this reply.
I've made a simple example using a TBarSeries:
uses Series, Types;
var XOffset, YOffset: Array of Integer;
MouseDownPos: TPoint;
var s, i: Integer;
Chart1.Legend.Visible:=false;
Chart1.View3D:=false;
with Chart1.AddSeries(TBarSeries) do
FillSampleValues;
Marks.Arrow.Color:=clRed;
SetLength(XOffset, Chart1[0].Count);
SetLength(YOffset, Chart1[0].Count);
for i:=0 to High(XOffset) do
XOffset[i]:=0;
YOffset[i]:=0;
with Chart1.Tools.Add(TDragMarksTool) as TDragMarksTool do
Series:=Chart1[0];
OnDraggedMark:=DragMarksOnDragged;
procedure TForm1.DragMarksOnDragged(Sender:TDragMarksTool; Index:Integer;
Button:TMouseButton; Shift: TShiftState;
X,Y: Integer);
if Assigned(Sender.Series) then
if (Index>-1) and (Index<Length(XOffset)) then
XOffset[Index]:=XOffset[Index]+X-MouseDownPos.X;
YOffset[Index]:=YOffset[Index]+Y-MouseDownPos.Y;
procedure TForm1.PlaceMarks;
var s, i, tmpSize, tmpX, tmpY: Integer;
Chart1.Draw;
for s:=0 to Chart1.SeriesCount-1 do
if Chart1[s] is TBarSeries then
with Chart1[s] as TBarSeries do
for i:=0 to Count-1 do
with Marks.Positions[i] do
tmpX:=CalcXPos(i);
tmpY:=CalcYPos(i);
Custom:=true;
LeftTop.X:=tmpX + BarWidth div 2 - Marks.Item[i].Width div 2 + XOffset[i];
if MarksOnBar then
if MarksLocation=mlEnd then
LeftTop.Y:=tmpY
tmpSize:=CalcYSizeValue(YValue[i]);
if MarksLocation=mlStart then
LeftTop.Y:=tmpY+tmpSize-Marks.Height
LeftTop.Y:=tmpY+(tmpSize div 2)-(Marks.Height div 2);
end
LeftTop.Y:=tmpY-Marks.ArrowLength-Marks.Height;
LeftTop.Y:=LeftTop.Y+YOffset[i];
ArrowFrom:=Point(tmpX+BarWidth div 2, tmpY);
ArrowTo:=Point(LeftTop.X+Marks.Item[i].Width div 2, LeftTop.Y);
procedure TForm1.Chart1Scroll(Sender: TObject);
PlaceMarks;
procedure TForm1.Chart1Zoom(Sender: TObject);
PlaceMarks;
procedure TForm1.Chart1UndoZoom(Sender: TObject);
PlaceMarks;
procedure TForm1.Chart1MouseDown(Sender: TObject; Button: TMouseButton;
Shift: TShiftState; X, Y: Integer);
MouseDownPos.X:=X;
MouseDownPos.Y:=Y;
Thanks, for the help. It has been along time since I had to work with these charts, could you add a bit more.
1. Supply the whole project so i can run the code and watch it work. (unknown items on compile MarksOnBar, MarksLocation, and mlEnd)
Or
2. Add some comments to PlaceMarks so I can figure out how to translate that into what I am doing.
Or
Sorry, I took part of the code from an example using a newer version.
I've tested this with TeeChart v8:
