WMF Image Size Requested may result in a different size
TestAlways
Post by TestAlways » Sat Oct 17, 2015 6:07 pm
Really strange problem here: When I set the Windows 7 display settings to 150% for larger text (both 100% and 125% work) TChart *may* return the wrong size image.
See the attached example, the WMF image below the chart should be a duplicate of the one above, just a different size. The caption shows what size the requested image was and what size was returned. Initially, the WMF image will return the wrong size (much large, with lots of margin on the right & bottom).
Change this to a BMP and not only is the correct size image return, returning to WMF results in the correct size image.
Any ideas on how to correct this?
Thank you,
Ed Dressel
compare3.zip
(3.88 KiB) Downloaded 1037 times
TestAlways
Re: WMF Image Size Requested may result in a different size
Post by TestAlways » Mon Oct 19, 2015 3:49 pm
I reproduced this problem in a fairly simple demo (attached) and posted it to the EMB forums as well. I have some frustrated customers about this and really need a fix soon.
Ed Dressel
WMF Canvas Size.zip
(1.49 KiB) Downloaded 1007 times
Post by Yeray » Tue Oct 20, 2015 7:57 am
I reproduced the problem with both applications in Windows 10. Note I reproduced the problem with both 125% and 150% Zoom:
TestAlways wrote:posted it to the EMB forums as well
I'll be glad to follow the issue there if you can share the link with us.
