TeeChart 2015 for RAD XE7.
When running New features Demo, the error as follows raises. How to solve the problem? Thanks.
Demo does not work
Demo does not work
- Err.jpg (38.74 KiB) Viewed 9826 times
Re: Demo does not work
Could you please add some extra information?
- What OS are you running? Is it 32 or 64 bits?
- Have you installed TeeChart Pro v2015.15 or v2015.16? Did you install it with high privileges?
Delphi 7 and XE 7 have been installed.
OS is 32 bits.
TeeChart pro with source 2015.16 has been installed. but no demo and raise errors as follows:
TeeChart Pro
Compilation started: 2016-1-18 8:58:08
Delphi v7 Enterprise
Tee97
Borland Delphi Version 15.0
Copyright (c) 1983,2002 Borland Software Corporation
TeCanvas.pas(8673) Warning: Variable 'P' might not have been initialized
TeEngine.pas(18148) Warning: Variable 'tmp' might not have been initialized
Series.pas(2459) Warning: Variable 'tmpMand' might not have been initialized
Series.pas(5472) Warning: Variable 'tmp' might not have been initialized
104938 lines, 0.73 seconds, 663132 bytes code, 10053 bytes data.
TeeUI97
TeeEdiGene.pas(1299) Warning: Variable 'tmpP' might not have been initialized
81382 lines, 0.25 seconds, 393020 bytes code, 1337 bytes data.
TeeDB97
8884 lines, 0.30 seconds, 49464 bytes code, 221 bytes data.
TeePro97
TeeMapSeries.pas(2614) Warning: Variable 'tmpP' might not have been initialized
TeeOrgSeries.pas(537) Warning: Variable 'tmpRoots' might not have been initialized
TeeTreeMapSeries.pas(424) Warning: Variable 'tmpRoots' might not have been initialized
TeeThemeEditor.pas(427) Warning: Variable 'p' might not have been initialized
TeeThemeEditor.pas(937) Warning: Variable 'tmp' might not have been initialized
TeeThemeEditor.pas(1010) Warning: Variable 'tmpColors' might not have been initialized
224552 lines, 0.66 seconds, 1025156 bytes code, 6493 bytes data.
TeeGL97
16390 lines, 0.34 seconds, 98712 bytes code, 3101 bytes data.
TeeImage97
40003 lines, 0.11 seconds, 281728 bytes code, 11617 bytes data.
TeeWorld97
3548 lines, 0.06 seconds, 22636 bytes code, 233 bytes data.
TeeLanguage97
85531 lines, 0.20 seconds, 2155884 bytes code, 3521 bytes data.
TeeImport97
6068 lines, 0.28 seconds, 47772 bytes code, 153 bytes data.
DclTee97
5348 lines, 0.48 seconds, 41436 bytes code, 257 bytes data.
DclTeePro97
3389 lines, 0.16 seconds, 28388 bytes code, 237 bytes data.
DclTGL97
645 lines, 0.05 seconds, 5316 bytes code, 125 bytes data.
TeeQR97
964 lines, 0.08 seconds, 10676 bytes code, 121 bytes data.
DclTQR97
659 lines, 0.06 seconds, 7832 bytes code, 125 bytes data.
DclTeeStd97
5345 lines, 0.06 seconds, 34828 bytes code, 237 bytes data.
DclTeeProStd97
3388 lines, 0.16 seconds, 27956 bytes code, 237 bytes data.
TeeMaker17
94795 lines, 0.44 seconds, 613152 bytes code, 28049 bytes data.
DclTeeMaker17
865 lines, 0.12 seconds, 14792 bytes code, 137 bytes data.
Compilation started: 2016-1-18 8:58:40
TeeTree2D7Tee9
47775 lines, 0.42 seconds, 417528 bytes code, 1437 bytes data.
DclTree2D7Tee9
1591 lines, 0.16 seconds, 10268 bytes code, 173 bytes data.
TeeChart Installation
VERSION: 2015
Installing...
Delphi v7 Enterprise OK. Time: 26s
Win32 v21 Architect (Delphi XE7 and C++Builder XE7 Update 1) (C++)
Tee921
Cannot recompile Delphi package: Tee921.dpk
Embarcadero Delphi for Win32 compiler version 28.0
Copyright (c) 1983,2014 Embarcadero Technologies, Inc.
VCLTee.TeeConst.pas(599) Error: E2066 Missing operator or semicolon
VCLTee.TeeConst.pas(599) Error: E2052 Unterminated string
VCLTee.TeeConst.pas(1001) Error: E2052 Unterminated string
VCLTee.TeeConst.pas(599) Fatal: E2280 Unterminated conditional directive
EXCEPTION:
Compilation aborted.
OS is 32 bits.
TeeChart Pro
Tee97
TeeUI97
TeeDB97
TeePro97
TeeGL97
TeeImage97
TeeWorld97
TeeLanguage97
TeeImport97
DclTee97
DclTeePro97
DclTGL97
TeeQR97
DclTQR97
DclTeeStd97
DclTeeProStd97
TeeMaker17
DclTeeMaker17
TeeTree2D7Tee9
DclTree2D7Tee9
VERSION: 2015
Installing...
Tee921
EXCEPTION:
When installed TeeChart 2015.15 or 16 in 32 bits, the Demo 32 can not run. The error is "lost rtl210.bpl".
I'd suggest you to install TeeChart with Sources again and make a backup of the "Sources" folder before doing anything else.
Then, you will always be able to take the original version of the files if anyone gets corrupted by any cause.
TeeConst may have been corrupted in your machine at some point between the installation (TeeChartVCLSOURCE-2015.16.150901.exe) and running TeeRecompile. This can happen when a compilation is ended unexpectedly.sripe wrote: Cannot recompile Delphi package: Tee921.dpk
EXCEPTION:
rtl*.bpl is distributed with the IDE, in bin folder of its installation. An error saying it can't be found usually means the PATH in your machine doesn't include a reference to that folder. For XE7 the paths I see in my machine are:sripe wrote:When installed TeeChart 2015.15 or 16 in 32 bits, the Demo 32 can not run. The error is "lost rtl210.bpl".
C:\Program Files (x86)\Embarcadero\Studio\15.0\bin
C:\Users\Public\Documents\Embarcadero\Studio\15.0\Bpl
C:\Program Files (x86)\Embarcadero\Studio\15.0\bin64
C:\Users\Public\Documents\Embarcadero\Studio\15.0\Bpl\Win64
For TPointSeries, when run to "HorizAxis := aTopAxis", it raise an error--"First chance exception at $006C596B. Exception class $C0000005 with message 'access violation at 0x006c596b: read of address 0x000000d8'". But, for TLineSeries, everything is ok.
What's up?
What's up?
mySeries: TPointSeries;
mySeries := nil;
with (mySeries as TPointSeries) do
HorizAxis := aTopAxis;
VertAxis := aLeftAxis;
I don't see how this relates to the demo (note the opening question and the thread title).
Please, open new threads to report or ask about new and different issues.
In your code I see you declare the mySeries variable to be of the TPointSeries type. But you aren't assigning a new instance of the class to the variable before accessing to it!
Also note you'll probably want to add the newly created series to a chart. If your TChart object is named Chart1:
Please, take a look at the Tutorials and to the Demos shipped with the installation.
mySeries:=TPointSeries.Create(Self);
Chart1.AddSeries(mySeries);
