How to fill the circle area with a picture for TPolarChart?
sripe
Post by sripe » Wed Jan 27, 2016 4:11 am
The following codes are OK for TLineChart, but they do not work for TPolarChart.
if OpenDialog1.Execute then
TheChart.BackImageInside := True;
TheChart.BackImage.LoadFromFile(OpenDialog1.FileName);
For TPolarChart , how to fill THE CIRCLE AREA with a picture?
Best Regards
Re: How to fill the circle area with a picture for TPolarChart?
Post by Yeray » Wed Jan 27, 2016 2:03 pm
I've filed the issue to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1417
As you'll see I've also found a workaround for it and I've also fixed it for the next maintenance release.
sripe
Post by sripe » Thu Jan 28, 2016 12:46 am
When assigning a BackImage or Gradient, how to make THE CIRCLE AREA transparent or not?
Post by Yeray » Thu Jan 28, 2016 9:21 am
This seems to work fine for me:
uses TeePolar;
var i: Integer;
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
  Chart1.Title.Visible:=false;
  Chart1.Gradient.StartColor:=RGB(240, 125, 20);
  Chart1.Gradient.MidColor:=RGB(150, 10, 240);
  Chart1.Gradient.EndColor:=RGB(200, 183, 225);
  for i:=0 to 1 do
    with Chart1.AddSeries(TPolarSeries) as TPolarSeries do
      FillSampleValues;
      Pointer.Visible:=false;
      Brush.Clear;
      Pen.Color:=Color;
      Pen.Width:=2;
      CircleBrush.Clear;
Don't hesitate to let us know if you still find problems with it.
sripe
Post by sripe » Fri Jan 29, 2016 5:43 am
“Fill” is to fill Gradient or Picture.
“Inside” is to fill Gradient or Picture in THE CIRCLE AREA, Otherwise to fill THE CHART PANEL.
When “Inside” checked, it does not work as I expected. Would you like to test and correct it for me?
Best regards
Example.zip
(58.84 KiB) Downloaded 576 times
Post by Yeray » Fri Jan 29, 2016 12:01 pm
sripe wrote:When “Inside” checked, it does not work as I expected. Would you like to test and correct it for me?
I'm sorry, the workaround wasn't correct. The good one is to clear CircleBrush. Ie, in your test application:
procedure TForm1.BitBtn2Click(Sender: TObject);
      Chart1.BackImageInside := CheckBox8.Checked;
      (ChartListBox1.SelectedSeries as TPolarSeries).CircleBrush.Clear;
      Chart1.BackImage.LoadFromFile(OpenDialog1.FileName);
sripe
Post by sripe » Sat Jan 30, 2016 4:36 am
Yes, it works to load a Picture. But, how to change the Gradient of THE CIRCLE AREA? Thanks.
Post by Yeray » Mon Feb 01, 2016 8:57 am
In your FormCreate, after clearing the CircleBrush, try assigning it a bsSolid TBrushStyle:
              CircleBrush.Clear;
              CircleBrush.Style:=bsSolid;
