How to use custom labels in TpolarSeries?
sripe
Post by sripe » Mon Jan 25, 2016 12:47 pm
Using TPolarSeries in TeeChart 2015, how to replace the original circleLabels at 0, 90, 180, 270 degrees with custom labels?
Re: How to use custom labels in TpolarSeries?
Post by Yeray » Mon Jan 25, 2016 2:07 pm
You can use the TPolarSeries' OnGetCircleLabel event for that. Ie:
procedure TForm1.PolarGetCircleLabel(Sender:TCustomPolarSeries; const Angle:Double;
                             Index:Integer; var Text:String);
  if Text='40°' then
    Text:='this was 40°';
sripe
Post by sripe » Tue Jan 26, 2016 5:14 am
Yes, it works. When Series1 exists, we can use the following procedure:
procedure TForm1.Series1GetCircleLabel(Sender: TCustomPolarSeries; const Angle: Double; Index: Integer; var Text: string);
if Text = '40°' then
Text := 'This was 40°';
But, if I create Series dynamically with codes, where to add and how to use the GetCircleLabel procedure? Would you like to give me an example?
Xiushan
Post by Yeray » Tue Jan 26, 2016 8:19 am
To assign an event at runtime you just have to declare the method at the top, as the others. Note the method needs to declare the same parameter types than the event expects. Then, you can assign the event to the series. Ie:
  private
    { Private declarations }
    procedure Series1GetCircleLabel(Sender: TCustomPolarSeries; const Angle: Double; Index: Integer; var Text: string);
  with Chart1.AddSeries(TPolarSeries) as TPolarSeries do
    FillSampleValues;
    OnGetCircleLabel:=Series1GetCircleLabel;
sripe
Post by sripe » Wed Feb 24, 2016 7:45 am
How to display Axis Labels at every Ticks?
Although I change the Label’s style and margins as far as possible, the Axis Labels do not display as crowded as expected (they are too sparse or few).
Post by Yeray » Wed Feb 24, 2016 9:31 am
You can modify the Increment:
GetVertAxis.Increment:=200;
However, if there isn't space for all the labels to be drawn, the circular grid will be drawn according to that Increment but the labels won't match.
In that case, you try setting a smaller font. Ie:
  Chart1.Axes.Bottom.LabelsFont.Size:=7;
  Chart1.Axes.Top.LabelsFont.Size:=7;
sripe
Post by sripe » Thu Feb 25, 2016 5:12 am
It seems that the labels arrangement on the BottomAxis not only relate to the BottomAxis component properties, but also relate to the CircleLabels properties. Sometimes, changing GetVertAxis.Increment or LabelsFont.Size do not get satisfied results. Generally, we expect to arrange the labels on the radial axes and the Radar/Polar circle, respectively. That is to say, the label’s properties on the radial axes and the Radar/Polar circle may be different. Do you have any good solutions to arrange the labels on the radial axes closely? Thanks a lot.
Post by Yeray » Fri Feb 26, 2016 3:48 pm
If I understand the problem correctly, you can use custom labels to manually place the labels you want. Ie:
uses TeePolar;
var i, tmp, tmpInc: Integer;
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
  Chart1.Gradient.Visible:=false;
    FillSampleValues;
    Pointer.Visible:=false;
    Brush.Clear;
    Pen.Color:=Color;
    CircleBrush.Clear;
  Chart1.Draw;
  with Chart1.Axes.Top do
    tmpInc:=Round((Chart1[0].MaxYValue-Chart1[0].MinYValue)/5);
    Items.Clear;
    for i:=0 to 4 do
      tmp:=Round(Minimum+(i*tmpInc));
      Items.Add(tmp, IntToStr(tmp));
