I bought the TeeChart pro version for delphi 7. When I want to animate a pie chart with label and percent values showing each portion are erroneous. The same applies to bar series, however if the sample values show well. See the attachment!
I would also like to know the version I sign says "TRIAL" if I have com meadow (TeeChart Pro v2015.14.150120 trial)?
And every time when modify a chart show error message "property detail not found"
Animations with label and percent error
- Sin título.png (22.06 KiB) Viewed 8058 times
Re: Animations with label and percent error
I've tried to reproduce the problem with this code but it seems to give me a correct percentage in the legend:
uses Series, TeeDonut;
with Chart1.AddSeries(TDonutSeries) as TDonutSeries do
AddPie(2185.85, 'Promotores');
AddPie(1236.47, 'Pasivos');
AddPie(662.83, 'Detractores');
Chart1.Legend.TextStyle:=ltsRightPercent;
If you mean in the aboutbox, this is a known issue we corrected in further releases.jars wrote:I would also like to know the version I sign says "TRIAL" if I have com meadow (TeeChart Pro v2015.14.150120 trial)?
Could you please arrange a simple example project we can run as-is to reproduce the problem here?jars wrote:And every time when modify a chart show error message "property detail not found"
Hi Yeray.
In the ErrorExample.zip attachment is the example that show after play animate button, labels percent always show 100%
In the ErrorImages.zip attachment are printscreens with the errors that was commented.
Jorge
Jorge
- ErrorImages.zip
- Images that show errors
- (158.38 KiB) Downloaded 497 times
- ErrorExamplet.zip
- Sample project
- (505.16 KiB) Downloaded 522 times
Thanks to your test application I could reproduce the problem with TeeChart v2015.14. I could also reproduce the problem with v2015.15.
However, it seems to work fine from 2015.16 and up. So I'd suggest you to update to the latest version available, v2016.18.
This version 2016.18 is valid for Delphi 7? It not appears as option?
From the v2016.18 TeeChart supports Delphi 7 only in the source code version. You'll find it in the "legacy" group.
