About palette's. How can I add my own "default " palettes, a
H.Hasenack (S&G)
Post by H.Hasenack (S&G) » Fri Jun 17, 2016 11:26 am
I want to add my own "fixed" palette definitions, but would rather not rewrite the tchart code too much .
:shock: Custom palette is currently only halfway implemented since it does not allow me to adda "named" palete in a sensible way.
I have modified some chart sources to allow my series to be linked to a fixed palette entry (through index).
Now I would like to add my own, named, palette definitions to the tchart editor palette list, but steema's code learns me the palette resolving is "hardcoded" through a case statement, rather than through a neatly organized dictionary or something like that.
:roll: See
class procedure TColorPalettes.GetPalette(Index:Integer; out Palette:TColorArray);
Any tips/hints on how to add my own custom, named palettes from within my own source code?
I would like something like:
ColorPalettes.AddPalette('MyAppPalette',cMyColorPaletteArray);
and off course it's counbterpart:
ColorPalettes.DeletePalette('MyAppPalette');
and for completeness,
ColorPalettes.Clear;
that makes sense.
Hans
Re: About palette's. How can I add my own "default " palettes, a
Post by Yeray » Mon Jun 20, 2016 2:48 pm
Hello Hans,
http://bugs.teechart.net/show_bug.cgi?id=1561
H.Hasenack (S&G)
Post by H.Hasenack (S&G) » Wed Jun 29, 2016 1:11 pm
I have implemented it already as I cannot wait on you guys to prioritize it. Here are the cganges I made to accomplish the functionality that I require.
It still lacks an UnregisterPalette routine.
ColorPalettes.Delete() and ColorPalettes.Clear will result in memory leaks, but should be fairly easy to fix. (I don't need it)
TeeProcs.pas
interface
type TColorArray=Array of TColor;
{$ifdef HH_PATCH_REGISTERPALETTE}
  PColorArray=^TColorArray;
{$endif}
Chart.pas
interface
  TColorPalettes=class(TStringList)
  public
    class procedure AddTo(const Items:TStrings; AddDefault:Boolean=False);
    class procedure ApplyPalette(const Chart:TCustomAxisPanel; Index:Integer); overload;
    class procedure ApplyPalette(const Chart:TCustomAxisPanel; const Palette:Array of TColor); overload;
    class procedure GetPalette(Index:Integer; out Palette:TColorArray);
    class procedure RegisterPalette(const aName:string; const aPalette: array of TColor);
    destructor Destroy; override;
{$endif}
  function ColorPalettes : TColorPalettes;
{$endif}
  vColorPalettes : TColorPalettes=nil;
{$else}
{$endif}
implementation
class procedure TColorPalettes.RegisterPalette(const aName:string; const aPalette: array of TColor);
  procedure lclCopyPalette(VAR aTargetPalette:TColorArray);
  VAR i:integer;
    SetLength(aTargetPalette,low(aPalette)+length(aPalette));
    for i:=low(aTargetPalette) to high(aTargetPalette) do
	  aTargetPalette[i]:=clTeeColor; // ensure entire array is initialized
    for i:=low(aPalette) to high(aPalette) do
      aTargetPalette[i]:=aPalette[i]; // actually copy palette entries
VAR idx:integer;
    PPalette:PColorArray;
  with ColorPalettes do
    idx:=IndexOf(aName);
    if idx>=0 then // replace existing named palette
      PPalette:=PColorArray(Objects[idx]);
      lclCopyPalette(PPalette^);
    end
    else // register new palette
      new(PPalette);
      AddObject(aName,TObject(PPalette));
destructor TColorPalettes.Destroy;
VAR i:integer;
    obj:TObject;
  for i:=0 to Count-1 do
    obj:=Objects[i];
    if Assigned(obj) then
      Objects[i]:=nil;
      setlength(PColorArray(obj)^,0);
      Dispose(PColorArray(obj));
  inherited;
  if not Assigned(vColorPalettes) then
    vColorPalettes:=TColorPalettes.Create;
    with vColorPalettes do
      RegisterPalette(TeeMsg_ThemeTeeChart,[]);                        //    0
      RegisterPalette(TeeMsg_ThemeExcel,ExcelPalette);                 //    1
      RegisterPalette(TeeMsg_ThemeVictorian,VictorianPalette);         //    2
      RegisterPalette(TeeMsg_ThemePastels,PastelsPalette);             //    3
      RegisterPalette(TeeMsg_ThemeSolid,SolidPalette);                 //    4
      RegisterPalette(TeeMsg_ThemeClassic,ClassicPalette);             //    5
      RegisterPalette(TeeMsg_ThemeWeb,WebPalette);                     //    6
      RegisterPalette(TeeMsg_ThemeModern,ModernPalette);               //    7
      RegisterPalette(TeeMsg_ThemeRainbow,RainbowPalette);             //    8
      RegisterPalette(TeeMsg_ThemeWinXP,WindowsXPPalette);             //    9
      RegisterPalette(TeeMsg_ThemeMacOS,MacOSPalette);                 //   10
      RegisterPalette(TeeMsg_ThemeWinVista,WindowsVistaPalette);       //   11
      RegisterPalette(TeeMsg_ThemeGrayScale,GrayScalePalette);         //   12
      RegisterPalette(TeeMsg_ThemeOpera,OperaPalette);                 //   13
      RegisterPalette(TeeMsg_ThemeWarm,WarmPalette);                   //   14
      RegisterPalette(TeeMsg_ThemeCool,CoolPalette);                   //   15
      RegisterPalette(TeeMsg_ThemeBlack,OnBlackPalette);               //   16
      RegisterPalette(TeeMsg_Metro,MetroPalette);                      //   17
      RegisterPalette(TeeMsg_iOSPalette,iOSPalette);                   //   18
      RegisterPalette(TeeMsg_AndroidPalette,AndroidPalette);           //   19
      RegisterPalette(TeeMsg_LookoutPalette,LookoutPalette);           //   20
      RegisterPalette(TeeMsg_SeawashPalette,SeawashPalette);           //   21
  Result:=vColorPalettes;
{$endif}
  procedure CopyPalette(const Source:Array of TColor);
  var t : Integer;
      {$IFDEF FMX}
      tmp : Byte;
      {$ENDIF}
    SetLength(Palette,Length(Source));
    for t:=0 to Length(Source)-1 do
    {$IFDEF FMX}
      Palette[t]:=Source[t];
      with TAlphaColorRec(Palette[t]) do
        tmp:=R;
        R:=B;
        B:=tmp;
        A:=$FF;
    {$ELSE}
        Palette[t]:={$IFDEF FMX}TAlphaColors.Alpha or {$ENDIF}Source[t];
    {$ENDIF}
    if InRange(Index,0,Count-1) then
      CopyPalette(PColorArray(Objects[Index])^)
    else CopyPalette([]);
{$else}
  case Index of
    1: CopyPalette(ExcelPalette);
    2: CopyPalette(VictorianPalette);
    3: CopyPalette(PastelsPalette);
    4: CopyPalette(SolidPalette);
    5: CopyPalette(ClassicPalette);
    6: CopyPalette(WebPalette);
    7: CopyPalette(ModernPalette);
    8: CopyPalette(RainbowPalette);
    9: CopyPalette(WindowsXPPalette);
   10: CopyPalette(MacOSPalette);
   11: CopyPalette(WindowsVistaPalette);
   12: CopyPalette(GrayScalePalette);
   13: CopyPalette(OperaPalette);
   14: CopyPalette(WarmPalette);
   15: CopyPalette(CoolPalette);
   16: CopyPalette(OnBlackPalette);
   17: CopyPalette(MetroPalette);
   18: CopyPalette(iOSPalette);
   19: CopyPalette(AndroidPalette);
   20: CopyPalette(LookoutPalette);
   21: CopyPalette(SeawashPalette);
    CopyPalette([]);
{$endif}
initialization
  Randomize;
  CheckTeeSeriesTypes;
  CheckTeeToolTypes;
  CheckTeeAnimationTypes;
{$ifndef HH_PATCH_REGISTERPALETTE}
  ColorPalettes.Add(TeeMsg_ThemeTeeChart);
  ColorPalettes.Add(TeeMsg_ThemeExcel);
  ColorPalettes.Add(TeeMsg_ThemeVictorian);
  ColorPalettes.Add(TeeMsg_ThemePastels);
  ColorPalettes.Add(TeeMsg_ThemeSolid);
  ColorPalettes.Add(TeeMsg_ThemeClassic);
  ColorPalettes.Add(TeeMsg_ThemeWeb);
  ColorPalettes.Add(TeeMsg_ThemeModern);
  ColorPalettes.Add(TeeMsg_ThemeRainbow);
  ColorPalettes.Add(TeeMsg_ThemeWinXP);
  ColorPalettes.Add(TeeMsg_ThemeMacOS);
  ColorPalettes.Add(TeeMsg_ThemeWinVista);
  ColorPalettes.Add(TeeMsg_ThemeGrayScale);
  ColorPalettes.Add(TeeMsg_ThemeOpera);
  ColorPalettes.Add(TeeMsg_ThemeWarm);
  ColorPalettes.Add(TeeMsg_ThemeCool);
  ColorPalettes.Add(TeeMsg_ThemeBlack);
  ColorPalettes.Add(TeeMsg_Metro);
  ColorPalettes.Add(TeeMsg_iOSPalette);
  ColorPalettes.Add(TeeMsg_AndroidPalette);
  ColorPalettes.Add(TeeMsg_LookoutPalette);
  ColorPalettes.Add(TeeMsg_SeawashPalette);
{$endif}
finalization
  FreeAndNil(vColorPalettes);
{$else}
  FreeAndNil(ColorPalettes);
{$endif}
  FreeSeriesTypes;
  FreeAndNil(TeeToolTypes);
  FreeAndNil(TeeAnimationTypes);
end.
