Chart Unexpectedly changes color with mouse movement
VideoTrack
Post by VideoTrack » Mon Aug 01, 2016 2:42 pm
One of the IDE's I need to maintain is Delphi 6. I also have XE2, Seattle and Berlin 10.1
I recently upgraded to Steema TeeChartVCLFMXSOURCE-2016.18
The installation went ahead without issue, including the D6 build. All OK.
Now after recompiling my software that uses the D6 IDE, sometimes when I mouse move over a chart area it completely changes color, not always, but most times.
It's quite unpredictable, sometimes when the mouse is only over the chart grid area itself, sometimes when the mouse is anywhere over the chart it suddenly completely changes color.
There is a mouse-move event associated with the chart to draw cross-hairs. That procedure has been there untouched for a long time.
//OnMouseMove Event code:
procedure TTTGraphPagesDlg.Estimated_TT_D2_ChartMouseMove(Sender: TObject;   Shift: TShiftState; X, Y: Integer);
{ This procedure draws the crosshair lines }
procedure DrawCross(AX,AY:Integer);
  with Estimated_TT_D2_Chart,Canvas do
    Pen.Color:=CrossHairColor;
    Pen.Style:=CrossHairStyle;
    Pen.Mode:=pmXor;
    Pen.Width:=1;
    MoveTo(ax,Estimated_TT_D2_Chart.ChartRect.Top-Height3D);
    LineTo(ax,Estimated_TT_D2_Chart.ChartRect.Bottom-Height3D);
    MoveTo(Estimated_TT_D2_Chart.ChartRect.Left+Width3D,ay);
    LineTo(Estimated_TT_D2_Chart.ChartRect.Right+Width3D,ay);
tmpX, tmpY : Double;
ix : Integer;
Lbl : ShortString;
ReturnedHMS : THrsMinSec;
{start of code}
  if (C2OldX<>-1) then
    DrawCross(C2OldX,C2OldY);  { draw old crosshair }
    C2OldX:=-1;
  { check if mouse is inside Chart rectangle }
  if PtInRect( Estimated_TT_D2_Chart.ChartRect, Point(X-Estimated_TT_D2_Chart.Width3D,Y+Estimated_TT_D2_Chart.Height3D)  ) then
    DrawCross(x,y);  { draw crosshair at current position }
    { store old position }
    C2OldX:=x;
    C2OldY:=y;
    { set label text }
    With Estimated_TT_D2_Chart.Series[2] do
      GetCursorValues(tmpX,tmpY); { <-- get values under mouse cursor }
      ix := trunc(tmpx);
      Lbl := Format('%2.2d:%2.2d', [(ix div 60),(ix mod 60)]);
      ReturnedHMS := Extended2HrsMinSec(tmpY*60);
      end; {With Estimated_TT_D2_Chart.Series[2]}
  end {if PtInRect}
  StatusBar2.simpleText:= '';
end; {procedure}
Please see attached images that show what happens to the chart display.
Any ideas what has caused this?
____________________________________________
Re: Chart Unexpectedly changes color with mouse movement
Post by Sandra » Tue Aug 02, 2016 12:03 pm
Hello VideoTrack,
Many thanks for the code you have sent us.
Could you attach for us the complete project? Or could you arrange for us a simple project where the problem appears?
We need reproduce exactly the problem here.
Thanks for your help,
VideoTrack
Post by VideoTrack » Wed Aug 03, 2016 3:03 am
Hello Sandra
I created a small project using all the same settings, and can get the problem to occur with this project, especially when moving the cursor near the scale graduation marks
It may be downloaded as a zip from this link:
https://www.dropbox.com/s/e0e3oaekzsm76 ... s.zip?dl=0
Trevor
Entire chart colors unexpectedly change
Post by Sandra » Wed Aug 03, 2016 3:07 pm
Hello Trevor,
Many thanks for the project
We can reproduce the problem you experiencing here and we have found a fix for the problem, is only needed modify the Estimated_TT_D1_ChartMouseMove method in same way below:
  with Estimated_TT_D1_Chart,Canvas do
    Pen.Color := clRed;
    Pen.Mode:=pmNotXor;
    Pen.Width:=1;
    MoveTo(ax,Estimated_TT_D1_Chart.ChartRect.Top-Height3D);
    LineTo(ax,Estimated_TT_D1_Chart.ChartRect.Bottom-Height3D);
    MoveTo(Estimated_TT_D1_Chart.ChartRect.Left+Width3D,ay);
    LineTo(Estimated_TT_D1_Chart.ChartRect.Right+Width3D,ay);
As you see I have used as Pen.Mode pmNotXor instead of pmXor and I have set the Pen color to Red.
Could you tell us if it fix the problem in your end?
Hoping this helps you
Thanks in advance
VideoTrack
Post by VideoTrack » Mon Aug 08, 2016 1:18 pm
Thanks. I tried changing the value, but this made it worse?
    //Pen.Mode:=pmXor;
    Pen.Mode := pmNotXor;
    Pen.Width:=1;
When the mouse was moved over the chart, the charts now went either yellow or pale green:
Incidentally, the code: Pen.Mode:=pmXor; has been there for about 10 years.
VideoTrack
Post by VideoTrack » Mon Aug 08, 2016 1:29 pm
Incidentally, the color change definitely seems to be related to moving the mouse over an adjacent control first, e.g. some text or other graphics object:
Post by Sandra » Tue Aug 09, 2016 11:40 am
Hello Trevor,
Many thanks for the information.
After, do some test I have realized you try to simulate a CursorTool.The same problem as you find the client there is in the thread below:
http://www.teechart.net/support/viewtop ... e4c#p50889
Therefore, I would like suggest you try to use a Cursor Tool for your requests and prevent possible problems.
Take a look at the examples under "All features\Welcome !\Tools\Cursor\". Also I have attached a simple example that Yeray made for the client of thread above.
MouseMoveUpdate.zip
(1.74 KiB) Downloaded 844 times
Could you tell us if it works in your end?
Thanks in advance
VideoTrack
Post by VideoTrack » Fri Aug 12, 2016 7:31 am
Thank you, that new code seems to work OK. Appreciate your assistance
Trevor
Post by Sandra » Fri Aug 12, 2016 8:10 am
Hello Trevor,
I'm glad the code works for you :).
Feel free to contact us if you have more questions.
Thanks in advance
