TeeChart Pro in Quick report designer 5.06 for Delphi XE8
Franta
Post by Franta » Wed Feb 22, 2017 7:06 am
how can I integrate TeeChart Pro into Quick report designer 5.06 for Delphi XE8?
(to create or modify quick report in my application)
I installed TeeChar in Delphi and package for quick report, It works. I can place a chart on form or on a report but only in delphi ide.
Tee chart wasn't integrated in TReportDesignerDialog so I can't work with chart in quick report when application is running...
How to add it to TReportDesignerDialog?
I need it works the same way as in the old version of quick report designer...see attached print screen of an old quick report designer, there is teechart integrated
thanks for help
Re: TeeChart Pro in Quick report designer 5.06 for Delphi XE8
Post by Yeray » Wed Feb 22, 2017 10:55 am
Have you asked QuickReport how to customize their TReportDesignerDialog?
Franta
Post by Franta » Wed Feb 22, 2017 12:09 pm
Hello, not yet, I am going to do it.
Franta
Post by Franta » Thu Mar 09, 2017 5:04 pm
I asked for it in QBS Software Ltd, producer of Quick Report
They lost source code for it.
We are trying to create a new source code, but we didn't succeed.
Can you help us?
There is attached unit which should register tqrchart in quick report designer
My application fails in initialization of unit qrd3rdpartycontrol_QRDTeeChar with message runtime error 217 at 004BC068
thanks for help
Franta
Post by Franta » Thu Mar 09, 2017 5:06 pm
the unit
qrd3rdpartycontrol_QRDTeeChart.zip
(2.05 KiB) Downloaded 720 times
Post by Yeray » Wed Mar 15, 2017 7:47 am
I've tried to use this unit in a Delphi 7 with QuickReport 5 installed, but I can't find any TQRepDesigner in my installation.
This is the palette I see in QuickReport tab:
Franta
Post by Franta » Wed Mar 15, 2017 12:49 pm
Hello, TQRepDesigner is/ was paid version of quick report. You need a PRO version of QR
thx
Post by Yeray » Thu Mar 16, 2017 1:08 pm
Here the list of components I get for QuickReport 6 Pro for RAD XE 10.1 Berlin. I can't find any *Designer*:
Franta
Post by Franta » Fri Mar 17, 2017 7:20 am
it isn't in QReport but in QRDesign
there is attached test project (delphi XE8), initialization in unit qrd3rdpartycontrol_QRDTeeChar is in {} (the part where it fails)
QRDesignerTest.zip
(66.43 KiB) Downloaded 658 times
Franta
Post by Franta » Wed Mar 29, 2017 5:57 am
Hello a new? a progress? thanks
Post by Yeray » Thu Mar 30, 2017 8:44 am
I've installed QRDesign into Berlin (QRD159QR6D10_1_Berlin_W64.exe) but it fails to load the component "QRDesign design-time" (dclqrd_DXE10_1.bpl).
The procedure entry point @Quickrpt@TCustomQuickRep@NewPage$qqro could not be located in the dynamic library E:\Program Files (x86)\Embarcadero\Studio\18.0\bin\QRD_DXE10_1_W64.bpl.
And when I try to open the project in the QRDesignerTest.zip in your last message, it fails to find class TReportDesignerDialog, probably because the component above failed loading.
I'll try to install QRDesign into XE8...
Post by Yeray » Thu Mar 30, 2017 9:39 am
Same error with RAD XE8 after installing QR6DXE8_W64_installer.exe and QRD159QR6DXE8W64.
Here the packages for the integration of TeeChart Pro v2017 into QuickReport v6 in RAD XE8:
Tee9QR6D22.zip
(147.87 KiB) Downloaded 775 times
Franta
Post by Franta » Thu Mar 30, 2017 9:10 pm
Hi, thanks
I found the problems, it works now some how... I miss border on the first chart...
Do you have a hint how to create chart editor fastly/ easily?
thanks
Post by Yeray » Fri Mar 31, 2017 8:29 am
Franta wrote:Do you have a hint how to create chart editor fastly/ easily?
The editor can be called as follows:
uses EditChar;
   EditChart(Self, QRDBChart1);
However, note the editor is designed to help the developers to build and test their applications, not to be accessed by the final users, so we don't recommend giving access to it.
Franta
Post by Franta » Sat Apr 15, 2017 8:47 am
EditChart works fine, but I miss Dataset in series/datasource
How can I add dataset? and how add list of tables...
(in Delphi IDE dataset and tables are available)
thanks
