Problems with binary installer...
Whookie
Post by Whookie » Wed Mar 22, 2017 2:31 pm
a few days ago I downloaded the latest VCL source release and installed it (hoping my Gradient problem with the TBarSeries got fixed) and everything worked fine.
Today I decided to install the binary version to get the demos (looking for the custom labels example) but when I try to install it and register it (with the same data I loged in here and used for the source installation) I get:
I tried it a few times and got unsure if one needs the Customer number instead of the License number but that seems to crash the installer...
Best regards
Whookie
Re: Problems with binary installer...
Post by Sandra » Wed Mar 22, 2017 4:13 pm
Hello Whookie,
I would like suggest you remove the Installer folder %Program Files (x86)%\Steema Software\Steema TeeChart Pro VCL FMX 2017.20 and download again the installer from the Client AccessPage. Then, run the installer with administrator rights and try install again the Teechart Pro VCL/FMX v2017.20.
Hoping this helps, otherwise don't hesitate to contact us.
Thanks in advance
Whookie
Post by Whookie » Thu Mar 23, 2017 8:53 am
Thx, deleting the folder did the trick!
Whookie
Post by Whookie » Sat Mar 25, 2017 9:46 am
... but after installation the demos are missin??
Whookie
Post by Whookie » Sat Mar 25, 2017 9:54 am
BTW. could you please split the binary installers to have demos/examples in en extra setup. as source-owner its always troublesome the get the demos (the binary installer constanly interfere with the source installation)?
Whookie
Post by Whookie » Mon Mar 27, 2017 8:50 am
I seems I had troubles with my backup-ssd. After I downloaded the installer again, there where all the options I needed (including not to install the packages into the IDE)!
Post by Sandra » Mon Mar 27, 2017 9:01 am
Hello Whookie,
I would like inform that after install the latest binary installer using Teechart Source Code License in my directory appears the Documentation and Examples folders. You can check that in the image below:
Therefore, you can't reproduce the problem you experiencing here.
I'm afraid it isn't possible at the moment. But, you have two options:
Use the compiled examples you find in the link below:
https://www.steema.com/downloads/vcl#tab2
Or use the Demos there are in the Github Steema repository. You find it in the link below:
https://github.com/Steema/TeeChart-VCL- ... ns-samples
Hoping this helps you
Thanks in advance
