DragMarks tool
DragMarks tool
Postby JimR » Tue Nov 14, 2017 4:08 am
If I have several point series on my chart. By making the DragMarksTool active I can just drag the marks for the points in the last series. How do I make the marks for all of the series drag-able? The number of series depends on the data so it has to be done at run time.
Thanks again,
Jim
JimR
Re: DragMarks tool
Postby Yeray » Tue Nov 14, 2017 7:31 am
Hello Jim,
Assigning nil to the TDragMarksTool's Series property should enable it for all the series.
An alternative is to set the TDragMarksTool's Series at OnMouseMove. Ie:
procedure TForm1.Chart1MouseMove(Sender: TObject; Shift: TShiftState; X,
  Y: Integer);
var SeriesIndex: Integer;
  for SeriesIndex:=0 to Chart1.SeriesCount-1 do
    if Chart1[SeriesIndex].Marks.Clicked(X, Y) > -1 then
       (Chart1.Tools[0] as TDragMarksTool).Series:=Chart1[SeriesIndex];
Image Image Image Image Image Image ImagePlease read our Bug Fixing Policy
Re: DragMarks tool
Postby JimR » Tue Nov 14, 2017 4:59 pm
Thanks - that first solution of setting the series property to nil is simple and it works. I would not have guessed that. What is the procedure to restore it to normal?
JimR
Re: DragMarks tool
Postby Yeray » Wed Nov 15, 2017 7:28 am
JimR wrote:Thanks - that first solution of setting the series property to nil is simple and it works. I would not have guessed that.
I'm glad to hear it works as you wish now.
JimR wrote:What is the procedure to restore it to normal?
By "normal" do you mean what you said in the opening post here?
JimR wrote:I can just drag the marks for the points in the last series
This is not the behaviour I observe by default. The TDragMarksTool works with all the series for me by default:
uses Series, TeeTools;
var i: Integer;
  Chart1.View3D:=False;
  for i:=0 to 3 do
    with Chart1.AddSeries(TPointSeries) do
      Marks.Visible:=True;
      FillSampleValues(5);
  Chart1.Tools.Add(TDragMarksTool);
What version are you using?
Re: DragMarks tool
Postby JimR » Wed Nov 15, 2017 12:12 pm
I meant your first example"
"Assigning nil to the TDragMarksTool's Series property should enable it for all the series."
How does one undo that ?
JimR
Re: DragMarks tool
Postby Yeray » Wed Nov 15, 2017 1:30 pm
JimR wrote:I meant your first example"
By default, Series is nil (1). You can check it with this example:
var i: Integer;
  for i:=0 to 3 do
  if (Chart1.Tools[0] as TDragMarksTool).Series = nil then
     Caption:='Series is nil'
     Caption:='Series is assigned';
If at some stage you assigned a Series to the TDragMarksTool to limit it (2), and later you set it to nil to use it in all the Series again (3), and you want to remember to what Series did you assign it at the beginning to reassign it (4), you can store the Series you assigned when setting to nil (at point 3). Ie:
var mySeries: TChartSeries;
  mySeries:=(Chart1.Tools[0] as TDragMarksTool).Series;
  (Chart1.Tools[0] as TDragMarksTool).Series:=nil;
And then restore that series (at point 4):
  (Chart1.Tools[0] as TDragMarksTool).Series:=mySeries;
Re: DragMarks tool
Postby JimR » Wed Nov 15, 2017 7:21 pm
ok, that is clearer. Thanks again.
JimR
Return to VCL
Who is online
Users browsing this forum: No registered users and 9 guests
