Good afternoon,
Delphi version: Delphi XE
TeeChart version: Teechart Pro v2018.24.180321 32bit VCL
I'm unable to correctly export a Donut chart to PDF.
In the attached files I show the chart in a TForm, the export options I select (I don't change any settings) and the PDF export result.
I simply place a new TChart on the screen, add a new Donut series and using the sample data I export the chart to PDF.
This happens when I export a Donut chart from a TForm.
It gets worse when I try to export a Donut chart in a report. I'm using Digital Metaphors Report Builder, version 14.07 Build 326.
Nothing but the legend is exported to PDF.
Any ideas on how this can be fixed? Is this a known issue?
Best regards,
Pedro Bento
Codeware, S.A.
Export Donut chart to PDF
- Export_Preview_Result.png (48.35 KiB) Viewed 6067 times
- Export_Preview.png (12.29 KiB) Viewed 6065 times
- Form_Chart.png (12.71 KiB) Viewed 6065 times
Re: Export Donut chart to PDF
Indeed the export to pdf seems to be broken for the TDonutSeries in 2D. I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=2031
In the meanwhile, it seems you can draw it in 3D and simulate a 2D setting Chart3DPercent to 0 and Elevation to 360:
Here a screenshot of the resultant pdf:
uses TeePDFCanvas, TeeDonut;
Chart1.Title.Caption:='Donut';
with Chart1.AddSeries(TDonutSeries) as TDonutSeries do
FillSampleValues(4);
Shadow.Hide;
Marks.Hide;
Chart1.Chart3DPercent:=0;
Chart1.Aspect.Elevation:=360;
TeeSaveToPDFFile(Chart1, 'C:\tmp\Chart1.pdf');
