TreeMap borders
Markus46
TreeMap borders
Post by Markus46 » Thu Nov 29, 2018 12:10 am
What properties of the TTreeMap series do I need to set to remove the borders around each box, including the outer box "A"?
I have tried
Series.Pen.Color := clWhite
Perhaps what I am seeing is a shadow? In that case, how to remove the shadow?
Also, what properties do I need to set to remove the space around each box? I'd like to show the boxes abutting each other.
I can't even see how to do these things using the Chart Editor GUI.
Mark
Re: TreeMap borders
Post by Yeray » Thu Nov 29, 2018 7:50 am
You should modify each Item Format. Ie:
var i: Integer;
  for i := 0 to Series1.Count-1 do
    with Series1.Item[i].Format do
      Pen.Visible:=False;
      Shadow.Visible:=False;
Markus46
Re: TreeMap borders
Post by Markus46 » Thu Nov 29, 2018 8:08 pm
Works like a charm!
Thanks so much :)
