TeeChart VCL/FMX 2018.26 Install in Rio
Lykke
Re: TeeChart VCL/FMX 2018.26 Install in Rio
Post by Lykke » Mon Dec 10, 2018 3:20 pm
I have only quickreport 5 installed no other 3rd party components. Don't know if this matters. It is otherwise a clean windows installation so should be easy to reproduce.
LanceRas
Post by LanceRas » Mon Dec 10, 2018 9:03 pm
I'm also having same exact issue. New clean Windows 10 VM with Rio installed with several third parties. AV at the start and no IDE's available. Using source code version.
ilmara
Post by ilmara » Tue Dec 11, 2018 7:37 am
Same problem here:
  • Access violation in TeeRecompile.exe on launch and cannot find Delphi 10.3
  • Binary installer finds 10.3 but cannot register. Launching TeeInstall.exe manually produce an access violation, then "TeeChart files cannot be found under current folder structure..." (default install path)
Post by Yeray » Tue Dec 11, 2018 7:56 am
We haven't been able to reproduce the problems here. We'll try to build a virtual machine to reproduce and debug the problem.
To do that, let's try to find something in common in the machines where it seems to be failing. Could you please tell us the following?
  • Are you using RAD, Delphi or C++Builder?
  • What Edition are you using, Community, Professional, Enterprise or Architect?
  • Did you install RAD 10.3 Rio using the Iso or the Web Install?
  • Did you install TeeChart Standard during Rio installation?
  • What Windows version are you using?
  • Do you have RAD 10.2 Tokyo or any previous version installed? Or, did you have it?
ilmara
Post by ilmara » Tue Dec 11, 2018 8:11 am
  • From the about box: "Embarcadero® RAD Studio 10.3 Version 26.0.32429.4364"
  • Professional
  • Web install
  • Installed without TeeChart
  • Windows 10 Pro version 1803
LanceRas
Post by LanceRas » Tue Dec 11, 2018 8:20 am
- Are you using RAD, Delphi or C++Builder?
RAD Studio (tho I use the Delphi profile almost exclusively
- What Edition are you using, Community, Professional, Enterprise or Architect?
Enterprise
- Did you install RAD 10.3 Rio using the Iso or the Web Install?
ALWAYS install from the ISO into a new Windows 10 VM
- Did you install TeeChart Standard during Rio installation?
Yes.
- What Windows version are you using?
Windows 10 1809 Enterprise x64
The access violation, my guess, is what is then preventing the list of IDE's to then show. Once you acknowledge access violation then you can point to the source path and then you are given the list of IDE's and platforms, which is all empty.
If you email me a link to any test installers, I'm willing to try. I am in Seattle so its Pacific time here and I'm usually here from 10:00 to 18:00.
Lance.
Post by Yeray » Tue Dec 11, 2018 8:58 am
Sorry, I've added an extra question to the list above:
Post by Yeray » Tue Dec 11, 2018 10:17 am
Thanks to all of you (but specially to Aidan), we've been able to reproduce the problem in a new virtual machine with RAD 10.3 Rio installed.
Every time the IDE is launched this key is recreated in the registry: "HKEY_CURRENT_USER\Software\Embarcadero\BDS\19.0"
The problem is RAD Rio is 20.0, while 19.0 was Tokyo. This seems to be confusing TeeRecompile and it probably tries to read some inexisting value.
This means, the new installers will be failing for all those who don't have Tokyo installed in their machines.
We've notified Embarcadero (RSP-22937) and we are trying to fix TeeRecompile.
As a workaround, you can create the "RootDir" string value in the "HKEY_CURRENT_USER\Software\Embarcadero\BDS\19.0" key with the data "C:\Program Files (x86)\Embarcadero\Studio\20.0\":
Then TeeRecompile should open and it should list both Tokyo and Rio. Please use only Rio since you don't have Tokyo installed:
Thanks for your patience.
appkeating
Post by appkeating » Tue Dec 11, 2018 10:34 am
Thanks for the mention Yeray :D
I can confirm that I was able to compile and install TeeChart with Rio.
In turn I was able to build all of our products with this version.
Cheers, Aidan.
asienaert
Post by asienaert » Tue Dec 11, 2018 11:26 am
Creating the registry key works for me. Tested on 2 different machines.
Post by Yeray » Tue Dec 11, 2018 11:54 am
I've just sent a mail with a new test installer.
If we get positive feedbacks we'll update the official version.
ilmara
Post by ilmara » Tue Dec 11, 2018 12:19 pm
No problem with TeeInstall.exe after creating the registry key. Thanks a lot for the help!
Post by Yeray » Tue Dec 11, 2018 1:15 pm
I'm glad to announce we've received enough positive feedback to continue to the next phase.
The official source code installers are already corrected and we are preparing the new binary installers.
LanceRas
Post by LanceRas » Tue Dec 11, 2018 5:49 pm
Confirmed updated installer / Recompilation tool is working as expected in Rio where Rio is only IDE that has been installed on a VM.
D.R.
Post by D.R. » Wed Dec 12, 2018 10:41 am
Dear Steema Team,
do you know, when binry installers are available
or is it possible to to install both at the same time?
Thank for your quick response until now :D
Dirk
