EdDressel wrote: ↑Fri Jun 21, 2019 3:57 pm
I can decrease the font size a bit, but how do I hide the background (via code please).
You can call "Marks.Brush.Clear".
Can I decrease the pie size a little?
You can manually set a CustomXRadius. Since the Cirlced property is set to true by default, you don't need to set the CustomYRadius.
Ie:
uses Series;
Chart1.View3D:=false;
Chart1.Legend.Hide;
Chart1.Title.Text.Text:='This is a title with a big font';
Chart1.Title.Font.Size:=20;
with TPieSeries(Chart1.AddSeries(TPieSeries)) do
AddPie(10, 'label 1');
AddPie(20, 'label 2');
AddPie(20, 'label 3');
AddPie(30, 'label 4');
Marks.Font.Size:=15;
Marks.Style:=smsLabelValue;
Marks.MultiLine:=True;
Marks.Brush.Clear;
CustomXRadius:=100;
- Project1_2019-06-27_12-28-45.png (21.17 KiB) Viewed 8008 times
Any other suggestions would be appreciated.
You could also write your own algorithm to move the marks, you could use the DragMarks tool to let the user move the marks manually, or you could set them to be inside the pie setting PieMarks.InsideSlice to True.
Note that the IDE is pretty confusing--it looks like there are several places to configure marks (chart editor/series]/[pie series]Marks and chart editor/series]/Format/Marks--I don't know the difference).
- The options in the "Series/Marks" tab are those related to the properties in TChartSeries.Marks. These properties are shared with all the other series.
- The options in the ""Series/Format/Marks" tab are those related to the properties in TPieSeries.PieMarks. These properties are only present in the PieSeries.
