Marks not working as expected with TChartShapes
Charlie SEI
Post by Charlie SEI » Tue Jan 14, 2020 7:05 pm
Hi!
I am making a chart using TChartShapes to create a Marginal Abatement Cost Curves (a series of rectangles showing costs and avoided carbon dioxide for a range of different measures). Its a pretty standard type of chart in my field. TChartShape series seemed like the best way to do this and they generally work very nicely.
However, I would like to label each block using Marks but TeeChart insists on showing two marks for each shape at two corners of each shape. See attached picture.
Can you offer some advice on how to fix this problem? Many thanks in advance.
I'm using Delphi 10.3.3 (32-bit) in Windows 10 using VCL version of TeeChart Pro v2019.27.
Below is code to demonstrate problem:
procedure TForm19.MACCBtnClick(Sender: TObject);
  Series: TChartShape;
  procedure _AddSer(x0, x1, y0, y1: double; name: string);
    Series := TChartShape.Create(Chart1);
    Series.Style := chasRectangle;
    Series.Title := name;
    Series.x0 := x0;
    Series.x1 := x1;
    Series.y0 := y0;
    Series.y1 := y1;
    Series.Color := clTeeColor;
    Series.ColorEachPoint := true;
    Series.Pen.Color := clGray;
    Series.Pen.Visible := false;
    Series.Marks.Style :=  smsLabelOrValue;
    Series.Marks.Visible := true;  //Shows 2 marks per shape
    Chart1.AddSeries(Series);
  Chart1.Axes.Left.Minimum := -500;
  Chart1.Axes.Left.Maximum := 500;
  Chart1.Axes.Bottom.Minimum := 0;
  Chart1.Axes.Bottom.Maximum := 100000;
  Chart1.FreeAllSeries;
  _AddSer(0, 2000, 0, -400, 'Methane Leaks');
  _AddSer(2001, 5000, 0, -200, 'Forestry');
  _AddSer(5001, 8000, 0, -30, 'Efficient AC');
  _AddSer(8001, 20000, 0, 40, 'Efficient Motors');
  _AddSer(20001, 30000, 0, 50, 'Wind');
  _AddSer(30001, 70000, 0, 350, 'Solar');
  _AddSer(70001, 80000, 0, 370, 'Carnon Capture and Storage');
  _AddSer(80001, 100000, 0, 450, 'Electric Vehicles');
MACC Curve using shape chart.jpg (63.12 KiB) Viewed 16600 times
Charlie SEI
Re: Marks not working as expected with TChartShapes
Post by Charlie SEI » Fri Jan 24, 2020 5:15 pm
Does anyone from STEEMA review or respond to messages on this forum?
Post by Marc » Thu Jan 30, 2020 3:06 pm
Sorry for the delay with this reply.
You could set the text for the shape and leave Marks.Visible False.
eg.
Series.Font.Color := clWhite;
Series.Text.Add('my text');
