rtech
Post
by rtech » Wed Apr 28, 2021 7:22 am
I need area series with two colours. One for negative and one for positive areas. (See attached screenshot for details)
I've done that by using OnAfterAdd:
void __fastcall MyFlowRateRectangleSeries::OnAfterAddPoint(TChartSeries *Sender, int ValueIndex)
if(Sender->YValues->Value[ValueIndex] > 0)
Sender->ValueColor[ValueIndex] = DefaultPosColor;
Sender->ValueColor[ValueIndex] = DefaultNegColor;
but it doesn't work automatically, only if I call OnAfterAdd in code:
NewSeries->AddXY(XValue, YValue);
NewSeries->OnAfterAdd(NewSeries, Index); //OnAfterAddPoint doesn't work without that line
also I want to apply new colours by pressing button, I need to redraw chart in OnClick handler for that?
- Screen1AreaSeries.JPG (40.03 KiB) Viewed 9988 times
Post
by Yeray » Mon May 03, 2021 10:43 am
Have you assigned your
OnAfterAddPoint
method to the series
OnAfterAdd
event? Ie:
NewSeries->OnAfterAdd=OnAfterAddPoint;
Yes, you need to repaint the chart after changing the colors.
rtech
Post
by rtech » Thu May 06, 2021 7:08 am
Have you assigned your OnAfterAddPoint method to the series OnAfterAdd event?
Yes, i've done it in my create series code:
TChartSeries *MyFlowRateRectangleSeries::CreateNewSeries()
auto NewSeries = MyAreaSeries::CreateNewSeries();
NewSeries->OnAfterAdd = OnAfterAddPoint;
return NewSeries;
But without that line
it doesn't work
Post
by Yeray » Fri May 07, 2021 10:34 am
This is working for me with a new simple example:
void __fastcall TForm1::FormCreate(TObject *Sender)
TAreaSeries *Series1=new TAreaSeries(this);
Chart1->AddSeries(Series1);
Series1->FillSampleValues();
Series1->OnAfterAdd=OnAfterAddPoint;
void __fastcall TForm1::Button1Click(TObject *Sender)
TChartSeries *s=Chart1->Series[0];
s->Add(s->YValues->MinValue+Random(s->YValues->Range()));
void __fastcall TForm1::OnAfterAddPoint(TChartSeries *Sender, int ValueIndex)
ShowMessage("New point added");
