logarithmic axis are scaled wrong in release 2022.36
WilliE
Post by WilliE » Fri Oct 21, 2022 11:39 am
we just upgraded to ver. 2022.36. We have a problem if the axis is scaled in logarithmic and auto mode. It looks like the axis is not scaled to the max value of the graph but to the next higher full decimal number (eg. 1000 or 10000 or 100000 ...)
In 2022.36 all was ok.
We use Delphi 11.1
Willi
Re: logarithmic axis are scaled wrong in release 2022.36
Post by Yeray » Mon Oct 24, 2022 9:19 am
Sorry, I guess you meant an older version. Could you please correct it so we can compare the changes?
Thanks!
axrvgareth
Post by axrvgareth » Mon Oct 24, 2022 4:46 pm
I have seen this as well, logarithmic scaling has changed from 2022.35 to 2022.36. See the attached images.
Version 2022.36
Plot 2022_36.png (36.75 KiB) Viewed 15653 times
Version 2022.35
Plot 2022_35.png (44.79 KiB) Viewed 15653 times
WilliE
Post by WilliE » Mon Oct 24, 2022 5:02 pm
Hello
In 2022.35 all was ok :)
Post by Yeray » Wed Oct 26, 2022 9:24 am
Hello Willi,
I could reproduce the problem so I've added it to the public tracker (#2564) and also fixed it for the next release.
WilliE
Post by WilliE » Wed Oct 26, 2022 11:50 am
Hello Yeray,
thank you very much. But is there a workaround because logarithmic scaling is very important for us?
Willi
Post by Yeray » Wed Oct 26, 2022 2:28 pm
Hello Willi,
If you own the sources, you can open the TeEngine.pas unit and substitute the TChartAxis.LogYPosValue function for this:
Function TChartAxis.LogYPosValue(Const Value:TChartValue):Integer;
  if IRangeLog=0 then result:=ICenterPos
    if Value<=0 then
       if not FInverted then result:=IEndPos
                        else result:=IStartPos
      if IRadiusAxis then
      Begin
        if FInverted then result:=Round((ILogMax-ln(Value))*(IAxisLogSizeRange/2))
                     else result:=Round((ln(Value)-ILogMin)*(IAxisLogSizeRange/2));
        result:=ICenterPos-result;
      end
      Begin
        if FInverted then result:=Round((ILogMax-ln(Value))*(IAxisLogSizeRange))
                     else result:=Round((ln(Value)-ILogMin)*(IAxisLogSizeRange));
        result:=IEndPos-result;
WilliE
Post by WilliE » Thu Oct 27, 2022 4:22 pm
Perfect :)
