Out Of Memory printing TeeChart (Delphi / ReportBuilder (Digital Metaphors)
UNIFORM-Agri
Post by UNIFORM-Agri » Wed Apr 12, 2023 12:36 pm
Hi all,
We experience Out Of Memory Exceptions when we print TChart (export to PDF) in our concurrent server environment.
I've managed to create an example application.
What I see is, when using ReportBuilder + Standard TeeChart delivered with Delphi, all seems to be OK.
When I install the TeeChart-pro version (rebuild TeeReCompile and RBTeePackageBuilder) and run the same application (rebuilded) I can reproduce 'Out Of Memory' quite frequent.
Precompiled binaries to try: https://we.tl/t-XAJMhrXBrM
To repoduce:
  • Open ReportBuilder_Test.exe (one of the 2 different compiled executables)
  • Hit button 'Start'
  • Exceptions will be logged, if none arise, try some times again.
I experience easier reproduction on my host-machine compared to run in a virtual environment.
Until now I didn't get the 'RBuilderTeeChartDelphi' example to break, but the 'RBuilderTeeChartPro' breaks quite easily.
Version info:
Delphi: 11.3.1
ReportBuilder: 22.01
TeeChart: 2023.38-beta
Sourcecode: in attachment (ReportBuilder.zip)
Callstack: in attachment (callstack.png)
Many thanks in advance!
ReportBuilder.zip
(347.58 KiB) Downloaded 1393 times
Re: Out Of Memory printing TeeChart (Delphi / ReportBuilder (Digital Metaphors)
Post by Marc » Thu Apr 13, 2023 3:55 pm
Thank you for the problem description and sample application. We are able to run your project and reproduce the error you report. The issues have some complexity so it will likely take us some time to work through possible causes. We'll get back to this thread.
UNIFORM-Agri
Post by UNIFORM-Agri » Thu Apr 13, 2023 5:52 pm
Thank you Marc, please let me know the result.
Post by Marc » Fri Apr 14, 2023 7:15 am
As a follow-up whilst we're looking at this. The problem doesn't seem to occur when tested with GDI (not GDI+).
If you'd like to test it, to see whether the output is at a level that is acceptable to you, the quickest way, if you're compiling with TeeChart sourcecode, is to set the default canvas here:
unit VCLTee.TeeProcs;
initialization
  //TeeDefaultCanvas:={$IFDEF FMX}''{$ELSE}'TGDIPlusCanvas'{$ENDIF}; //commenting this line
  TeeDefaultCanvas:='';  //<- adding this line
There's a registry setting that controls that I think; I'll need to check, but the sourcecode mod will let you test it.
UNIFORM-Agri
Post by UNIFORM-Agri » Fri Apr 14, 2023 11:03 am
Hi Marc,
Yes I can confirm that switching to GDI don't give us errors (until now)!
With developer-eyes the generated images are still good enough :D
I had some troubles setting up to build with source, can you confirm the steps to do?
  • Add VCLTee to unit scope names
  • Add Source\VCL to library path (not source\ itself)
  • Add RBuilder\Source to library path (as we use RBuilder to print the charts)
Do I understand correctly that you're still looking for a final solution?
Post by Marc » Fri Apr 14, 2023 1:44 pm
Yes, we'll run some checks. GDI+ is known to suffer problems when many handles are requested via multiple threads but we are curious that it should have behaved differently with the TeeChart Standard version shipped with Delphi so we'll look for differences.
Post by Marc » Fri Apr 14, 2023 1:52 pm
Reviewing your steps:
Yes.
Yes, the Source\VCL folder. At project level: Project Options, Building, Delphi Compiler Search path.
Yes, again, at project level, added this folder to the Search path too:
..program files ..\Embarcadero\Studio\20.0\RBuilder\TeeChart\Win32\TeePro900
UNIFORM-Agri
Post by UNIFORM-Agri » Wed May 10, 2023 6:54 am
I just see beta2 (2023.38.230508) is rolled out.
Should this version fix these GDI+ errors?
Post by Yeray » Fri May 12, 2023 9:31 am
I'm afraid there's still a problem with using GDIPlus in multiple threads.
Since metafile doesn't require GDIPlus, the workaround is to set GDI canvas.
