TeeChart Pro for XE2 pre-release binary installer
Re: TeeChart Pro for XE2 pre-release binary installer
Post by Yeray » Fri Nov 04, 2011 2:12 pm
Hi Gregg,
Great!
It's probably a component that integrates TeeChart into FastReports. If you need this component, you'll need to recompile it with the TeeChart Pro packages you are actually using. Contact FastReport guys for the instructions to do it, so they are who support this integration. Here I see some instructions but I don't know if they are valid for the actual TeeChart binary PreRelease and XE2.
I hope Michael has a similar problem.
Michael Schustereder
Post by Michael Schustereder » Fri Nov 04, 2011 2:54 pm
I deinstalled fastreport (which I did not use) and I deinstalled RBBuilder. Afterwards I reinstalled the TeeChart-Components, but I get the same problem.
I use further 3rd party components, but I cannot deinstall all these components to see, if teechart can correctly install. Now I'm waiting to your "release" installer and hope, that the installer works fine.
Yours,
Michael
Post by Yeray » Fri Nov 04, 2011 3:36 pm
Hello Michael,
The stable release will probably present the same "problem". I think you misunderstood the procedure to find what component is causing the confusion. You don't need to completely uninstall the components, just to unselect them in the packages list and try to select the TeeChart Pro one.
Post by Michael Schustereder » Fri Nov 04, 2011 3:50 pm
Hello Yeray,
sorry, for the misunderstanding. The DevExpress Printing System also use TeeChart-Komponents.
Thanks for your help.
Yours,
Michael
Post by Yeray » Fri Nov 04, 2011 3:54 pm
Hello Michael,
I'm glad to hear it! Then, the same reply above applies for the TeeChart integration in DevExpress. The integrations supported by Steema Software are with QuickReport and IntraWeb.
Manfred
Post by Manfred » Mon Nov 07, 2011 10:00 am
I installed the latest pre-release with the latest update of RAD Studio XE2.
Everything seems to function without problems. But, I encountered a dysfunction of Axis Breaks within Tools opened within TCommander. It simple is inactive and does not create a break.
Best regards,
Manfred
Post by Yeray » Tue Nov 08, 2011 10:48 am
Hello Manfred,
Right, the AxisBreaksEditor in this PreRelease isn't correctly called. We'll revise it.
kjm
Post by kjm » Tue Nov 15, 2011 4:07 pm
Do these "XE2" versions work with Rad Studio XE (with all updates)?
I was unable to determine this from the version descriptions.
K
Post by Yeray » Wed Nov 16, 2011 12:36 pm
Hello kjm,
There is a binary installer for each IDE and this PreRelease version is just the installer for XE2.
However, being SourceCode customer gives access to the SourceCode PreRelease version, also thought for XE2 but supporting all the IDEs.
Tee8Beta
Post by Tee8Beta » Sun Nov 20, 2011 12:21 pm
Today I tried to install Tee9upd2 binary for the XE2.
First of all the install was done fine, the second, when I tested the FMX version of the Tee9, I could put Tchart to the form but the chart editor is empty and did not show the series palette.
The last problem - I could not recompile professional FastReport 4.12 for the Tee9 as the TeeEdit.dcu file is absent.
Post by Yeray » Mon Nov 21, 2011 10:06 am
We've just published the v2011.04 final release:
http://www.teechart.net/support/viewtop ... =3&t=12826
anauta wrote:First of all the install was done fine, the second, when I tested the FMX version of the Tee9, I could put Tchart to the form but the chart editor is empty and did not show the series palette.
Could you please try with the final release?
vlezhu
Post by vlezhu » Mon Nov 21, 2011 10:54 am
Thank you, I'll try today enening.
