Problems with EMF files on Surface Pro
Data Innovations
Re: Problems with EMF files on Surface Pro
Post by Data Innovations » Thu Nov 17, 2016 12:50 pm
The EMFs that we are seeing on the Surface Pro in our application (not in the test program) are exactly twice as large as they should be, if that is of any help/interest.
Post by Yeray » Fri Nov 18, 2016 9:38 am
Thanks for the information. We'll try to reproduce the problem in a virtual machine to be able to continue investigating the problem.
Data Innovations
Post by Data Innovations » Fri Nov 18, 2016 1:00 pm
OK. Thank you. I will return the Surface Pro to it's owner. Thanks for your support.
Post by Yeray » Tue Nov 22, 2016 9:00 am
I found some problems to emulate the resolution of the Surface Pro 3 here (2160x1440). Finally I achieved it doing this, but I'm afraid I can't reproduce the problem with a virtual machine running the same OS and resolution:
Delphi_User
Post by Delphi_User » Tue Nov 22, 2016 3:53 pm
Hello.
I compiled SurfaceProTestDelphi project on Delphi XE8 (TeeChart Pro v2016.19.161025 32bit).
Tested on device Pipo X10 (Windows 10 version 1511 build 10586.589).
There I have even bigger difference so I think it is because on surface desktop was scaled by 150% and on Pipo I have scaled by 200%.
pipo
Post by Yeray » Wed Nov 23, 2016 8:43 am
Thank you. This reminded me a similar case. I think we can assume this comes for the same issue:
http://www.teechart.net/support/viewtop ... =3&t=15815
https://forums.embarcadero.com/thread.j ... 4&tstart=0
