Chart possible with Teechart?
vinc64
Re: Chart possible with Teechart?
Post by vinc64 » Fri Jul 06, 2018 9:07 am
I have set the following code but the function never gets called, is there an alternative?
Chart1.OnGetAxisLabel := Chart1GetAxisLabel;
Post by Yeray » Mon Jul 09, 2018 7:02 am
As soon as there's a series with data in the chart, it should be called. Could you please arrange a simple example project we can run as-is to reproduce the problem here?
vinc64
Post by vinc64 » Sun Jul 22, 2018 2:51 pm
Apologies for the late reply (was away for 2 weeks). I tried it out in a smaller program and the event-handler is called, hence must be a problem in my code.
Thanks for all the help.
Post by Yeray » Mon Jul 23, 2018 7:18 am
Sorry, I forgot to mention the OnGetAxisLabel isn't fired for an axis when you set it with custom labels. In this case you already control what texts are drawn and at what positions so you shouldn't need the event.
vinc64
Post by vinc64 » Mon Jul 23, 2018 8:06 am
Thanks for the additional feedback.
vinc64
Post by vinc64 » Thu Aug 02, 2018 9:19 am
For the text being shown in a shape, is there a way to wrap it in case it doesn't fit into a rectangle?
Post by Yeray » Tue Aug 14, 2018 10:47 am
Instead of formatting the texts with sLineBreak as I do at GetText function, you could use wraptext function once the chart has been drawn. Ie, at the end of your FormCreate:
var textW, shapeW: Integer;
  Chart1.Draw;
    with Chart1[i] as TChartShape do
      Chart1.Canvas.AssignFont3D(Font);
      textW:=Chart1.Canvas.TextWidth(Text.Text);
      shapeW:=Bounds.Right-Bounds.Left;
      if textW>shapeW then
        charW:=Chart1.Canvas.TextWidth('W');
        Text.Text:=WrapText(Text.Text, shapeW div charW);
  Chart1.Draw;
vinc64
Post by vinc64 » Thu Aug 16, 2018 12:23 pm
Thanks for the additional help.
