Calou
- Advanced
Post
by Calou » Mon Nov 23, 2009 10:10 am
Here is the code to save charts to file
SaveChartToFile(ChrtProdSynthese,frmMain.PathAppli+'Config\GraphSynthese0.tee',FALSE);
SaveChartToFile(ChrtDispoSynthese,frmMain.PathAppli+'Config\GraphSynthese1.tee',FALSE);
SaveChartToFile(ChrtVitSynthese,frmMain.PathAppli+'Config\GraphSynthese2.tee',FALSE);
SaveChartToFile(ChrtRealTheoSynthese,frmMain.PathAppli+'Config\GraphSynthese3.tee',FALSE)
Here is the code to load the charts
SetLength(frmMain.ChrtModel,4);
//si un fichier de config des courbes existe on le charge
for i := 0 to High(frmMain.ChrtModel) do
if FileExists(frmMain.PathAppli+'Config\GraphSynthese'+IntToStr(i)+'.tee') then
frmMain.ChrtModel[i]:=TChart.Create(self);
LoadChartfromFile(frmMain.ChrtModel[i],frmMain.PathAppli+'Config\GraphSynthese'+IntToStr(i)+'.tee');
When the loadchartfromfile is called with i=1 i have the message "components named _1 already exists"
I don't understand why ?
Thanks for help
Calou
- Advanced
Post
by Calou » Mon Nov 23, 2009 12:10 pm
I have done some other tests.
The error occur only when i use the TADVStringGrid (version 5) from TMSSoftware.
You can do a simple exampe. If you call loadchartfromfile with a TadvSTringgrid on the form it crashes
Post
by Yeray » Mon Nov 23, 2009 12:21 pm
Hi Calou,
I've been doing some tests to try to reproduce the error but couldn't. Here is the complete demo example I've been testing with:
uses Chart, Series, TeeStore, TeeEditPro;
var Charts: array[0..3] of TCustomChart;
var i: Integer;
for i:=0 to length(Charts)-1 do
Charts[i]:=TChart.Create(self);
Charts[i].Parent:=Form1;
Charts[i].Left:=Charts[i].Width*(i mod 2);
Charts[i].Top:=Charts[i].Height*(i div 2);
case i of
0: Charts[i].AddSeries(TPointSeries.Create(self));
1: Charts[i].AddSeries(TBarSeries.Create(self));
2: Charts[i].AddSeries(TLineSeries.Create(self));
Charts[i].AddSeries(TFastLineSeries.Create(self));
Charts[i][0].FillSampleValues();
var i: Integer;
SaveChartToFile(Charts[i],'C:\tmp\Chart' + inttostr(i) + '.tee',true,true);
procedure TForm1.Button2Click(Sender: TObject);
var i: Integer;
FileName: string;
for i := 0 to length(Charts)-1 do
FileName:='C:\tmp\Chart' + inttostr(i) + '.tee';
if FileExists(FileName) then
LoadChartfromFile(Charts[i],FileName);
As you say, this could be due to another component compatibility problem. Please check if you can obtain a simple string from the TADVStringGrid, if there are related problems with that component and if you can reproduce the error without using TeeChart or without TadvSTringgrid.
Calou
- Advanced
Post
by Calou » Mon Nov 23, 2009 12:58 pm
I have tested your example
Without the ADVSTringGrid no error. With the ADVStringGrid there is the error (name _1)
After called the LoadChartFromfile Function, without AdvStringGrid the name of charts (Charts.name) is '' and with the AdvStringGrid it is '_1'
It is the same behavior if charts is not an array
Thanks for help
Calou
- Advanced
Post
by Calou » Mon Nov 23, 2009 1:39 pm
I am not able to reproduce this behavior with only AdtStringGrid.
Let me know if you want that i do others tests
Calou
- Advanced
Post
by Calou » Tue Nov 24, 2009 8:45 am
Have you found something? Sorry to insist but my developpement is stopped now
Thanks for feedback
Post
by Yeray » Tue Nov 24, 2009 3:56 pm
Hi Calou,
I've been testing this and yes, it seems that having a TAdvStringGrid in the same form than a Chart, makes the following code to crash the second time the button is pressed (the second time the chart is imported).
But I've also found that freeing the chart variable seems to solve the problem:
var Chart1: TCustomChart;
FileName: string;
Chart1:=TChart.Create(self);
Chart1.Parent:=Self;
Chart1.AddSeries(TPointSeries.Create(self));
Chart1[0].FillSampleValues();
FileName:='C:\tmp\Chart1.tee';
SaveChartToFile(Chart1,FileName,true,true);
//Chart1.Free; //This seems to solve the problem when a TAdvStringGrid is in the form
LoadChartfromFile(Chart1,FileName);
Calou
- Advanced
Post
by Calou » Tue Nov 24, 2009 4:24 pm
hello,
I have modified your example like this :
var i: Integer;
FileName: string;
Charts[i].free;//for test with advstringgrid
But i always have the error
Calou
- Advanced
Post
by Calou » Wed Nov 25, 2009 3:47 pm
I am very sorry to insist
but have you find something to correct the problem?
Thank you very much for the feedback
Post
by Yeray » Wed Nov 25, 2009 4:04 pm
Hi Calou,
We will study the problem and to be back to you asap. If you want, you can get
priority support.
Calou
- Advanced
Post
by Calou » Wed Nov 25, 2009 4:07 pm
Many thanks Yeray
Post
by Yeray » Wed Nov 25, 2009 4:37 pm
Hi Calou,
Adding the following line in the for loop, just before the LoadChartFromFile call, seems to solve the problem. Could you please verify it?
Charts[i].Name:='Chart' + inttostr(i);
Calou
- Advanced
Post
by Calou » Wed Nov 25, 2009 5:10 pm
I will do more tests tomorrow but it seems to be good
Many thanks
