chartrect does not autosize based on custom axis label
davidnovo
Post by davidnovo » Tue Jan 19, 2010 10:01 pm
If you have a chart that has a label on a customAxis, it seems that the chartrect does not resize based on whether the label is visible or not, or what the text of the axis title. If I use the exact same chart, but link the series to one of the default axes, then the chartrect resizes automatically to accomodate the axis title.
Is there a way to make the chart rect resize to accomodate the axis title of custom axes, if custom axes are being used on the plot?
Re: chartrect does not autosize based on custom axis label
Post by Narcís » Wed Jan 20, 2010 8:41 am
Hi davidnovo,
Custom axes don't calculate margins automatically. You can either set desired margin manually or for a more dynamic solution implement something as the PlaceAxes method Yeray posted here.
dave novo
Post by dave novo » Wed Jan 20, 2010 3:41 pm
Hi Narcis,
This should definitely be added as part of the standard behavior. If I have a plot use custom axes, why would I ever want TChart to only base the margin on one of the standard axes? The code that Yeray wrote should be incorporated as a standard part of the chartrect calculation!
Post by Narcís » Thu Jan 21, 2010 8:34 am
This is on the wish-list to be considered for inclusion in future releases.
cholzner
Post by cholzner » Tue Feb 09, 2010 6:38 pm
Please note that I am also eagerly waiting for that "feature".
Rgds,
Christian
hel
Post by hel » Mon Nov 06, 2017 11:05 am
Any progress on this "feature"?
Is there an "easy" way to place a custom axis outside of the Chart rectangle without doing mad assumptions about Axis Title and Labels sizes?
Roumen
Post by Yeray » Tue Nov 07, 2017 8:41 am
No, I'm afraid #126 hasn't been implemented yet.
What do you consider to be "mad assumptions" in the example pointed out above?
