Problem with editor dialogs
madupree
Post by madupree » Sat May 15, 2010 5:41 am
I am and have had a problem with the editor dislogs when the screen size is greater the 1024 x768.
This happens in V8 (and before) just have more clients with high density screens so becoming more of an issue
Mike
Re: Problem with editor dialogs
Post by Narcís » Mon May 17, 2010 8:26 am
Hi Mike,
Could you please elaborate in which is the exact problem you are having with this?
madupree
Post by madupree » Mon May 17, 2010 11:36 am
For example using a notebook with screen 1920 x 1200
Open Editor
Select General tab Zoom
Select Pen you cannot see Width and Space editors
On this dialog the caption "Border Editor"
The righthand side hides most of the text and the spineditors
the box does not resize with screen resolution correctly ?
Mike
Post by Narcís » Mon May 17, 2010 11:51 am
Hi Mike,
I haven't been able to reproduce but I'm not 100% sure on how to do it. Could you please attach a screenshot of what you get?
madup
Post by madup » Mon May 17, 2010 12:16 pm
Attached is screenshot
Mike
Editor box problem
Post by Narcís » Mon May 17, 2010 1:19 pm
Hi Mike,
Thanks for the image. The problem I see here is not screen resolution but Windows' fonts set to "large fonts (120 DPI). This is a known issue (TV52011726) we will try enhance for future releases. Works fine with 96 DPI fonts. Can you please confirm problematic environments use 120 DPI fonts?
madupree
Post by madupree » Tue May 18, 2010 9:14 am
Hi Narcis,
You've got it correct.
In most cases with the high/dense screen settings, the large font is greater than 96 dpi.
On 96 dpi machines it's fine
Mike
Post by Yeray » Wed May 19, 2010 8:48 am
Hi madupree,
I cannot reproduce the problem in TeeChart 2010. Could you please confirm it? (You can download the eval or run the precompiled demos)
http://www.steema.com/download/vcl
madup
Post by madup » Wed May 19, 2010 10:40 pm
Yes it is much better in VCL2010 using the Demos.
How ever it is close to cutting off the right edge (see attachement)
However it is usable
Mike
