Teechart VCL 2010 Strange Chart
TeeChart VCL / CLX for Borland Delphi, C++ Builder and Kylix.
Postby danielchart » Thu Jul 29, 2010 9:53 am
Hi:
Pls. see the attached images.
After I change from Teechart 7 to Teechart 2010.
Using Teechart 2010, The charts become very strange after pull down scroll bar.
But this program works fine by Teechart 7.
How do I solve this problem?
Daniel
After pull down scroll bar
AfterSelect Options.PNG (288.59 KiB) Viewed 102 times
Before pull down scroll bar
danielchart
Re: Teechart VCL 2010 Strange Chart
Postby Yeray » Fri Jul 30, 2010 2:35 pm
Hi Daniel,
You could try calling Draw() method at your ScrollBar OnChange event.
Also note that we've introduced some changes to the internal repainting for maybe related reasons, so this could fix you problem in the next maintenance release:
viewtopic.php?f=3&t=11250
If you can send us a simple example project we can run as-is to reproduce the problem here, we'll try it in the latest sources so we can tell you if the next maintenance release will fix it or not.
Best Regards
Yeray Alonso
Steema Support Central
http://support.steema.com/
http://twitter.com/SteemaSoftware
Return to VCL / CLX
Who is online
Users browsing this forum: No registered users and 1 guest
cron
