WaterfallSeries - Inverted Depth Axis
Heinz
Post by Heinz » Mon Aug 23, 2010 8:01 am
using WaterfallSeries and setting the property Inverted for the Depth Axis results in a steady access violation.
Any suggestion to fix the problem?
Best regards
Heinz
P.S.: I'm working with version 8.04
Re: WaterfallSeries - Inverted Depth Axis
Post by Yeray » Mon Aug 23, 2010 4:00 pm
Hi Heinz,
I could reproduce it so I've added it to the defect list to be fixed in future releases (TV52015102).
I'm afraid I can't think on a workaround for this.
Post by Yeray » Wed Aug 25, 2010 2:43 pm
Hi Heinz,
Could you please try with the latest version available in the client area?
Heinz
Post by Heinz » Mon Sep 06, 2010 11:06 am
I tried it with 8.07 and it seems to behave the same.
Best regards
Heinz
Post by Yeray » Wed Sep 08, 2010 1:09 pm
Hi Heinz,
Could you please tell us in what IDE are you getting the problem? I can't reproduce it with the v8.07 neither in Delphi 7 or RAD Studio 2010.
Heinz
Post by Heinz » Thu Sep 09, 2010 11:31 am
I did a countercheck: I only put a TChart-component onto a form, created a Waterfall-series and filled it with random values. And it works - even with 8.04 and Delphi7 !
Then I exported the tee-file ( the attached file: WFTest.tee) and opened it with TeeChart-Office 3.0.
Now I changed the Depth-Axis property to inverted .......and as soon as the mouse is moved over the chart the exception occurs.
Best regards
Heinz
WFTest.zip
WFTest.tee
(82.24 KiB) Downloaded 371 times
Post by Yeray » Fri Sep 10, 2010 12:44 pm
Hi Heinz,
Thank you for the information. I've updated the issue information.
